Cell Phones Logo
m
melvin Posted on Dec 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't seem to connect to wi-fi
Cannot get connected to wifi
Claude Kayser
Level 3:
Top Expert:
  • Cell Phones Master 9,098 Answers
  • Posted on Dec 19, 2015
Claude Kayser
Cell Phones Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067302
Points
28436
Cannot Connect to Wi-Fi - Troubleshooting your ... - Samsung
www.samsung.com > Home > Support > Cell Phones
Samsung ElectronicsFAQ00061225 I cannot connect to Wi-Fi® on my Samsung device. ... On the mobiledevice, attempt to connect to the Wi-Fi network. If you are not able to connect ...
What to Do When Your iPhone Won't Connect to Wi-Fi
1helpful
3answers
Why is my brother printer not connecting to wifi
Assuming that you're using Windows 10, most printers seem to have problems with printing through wifi, especially if you've just made some major updates to Windows 10. Try these steps first - #1 You might have to reinstall the software and/or the driver for your computer. If it still doesn't work, try printing with windows default driver. If nothing works, then the best thing is to print using a USB cable.
2helpful
My tablet will not connect to my internet
Can't connect to Internet through WiFi on Android Tablet/Phone. ... 4.Try to turn off/on Wi-Fi on the device. Turn off Wi-Fi first, [Settings]>>[Wi-Fi] >>[OFF]. Then turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[ON].
Can't connect to Internet through WiFi on Android Tablet/Phone - Asus
www.asus.com/UK/support/FAQ/1003867 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=tablet%20will%20not%20connect%20to%20my%20internet
How to connecting wifi networks
Hello Pavan kalya naidu,
Please go to mobile setting and turn on wi-fi on your mobile phone.
Now wi-fi network is on.
below your are showing wi-fi connection names.
now click on wi-fi connection and connect.
now asking for password.
enter correct password and click ok .
now your wi-fi connect on your mobile phone .
Thanks,
Mar 18, 2016 • Cell Phones
1helpful
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
My samsung star wifi can not connect to my router
1. Tap the "Menu" button from the home screen of your Samsung Star phone.
2. Tap "Wi-Fi" and select the "ON" option.
3. Select the Wi-Fi router you want to connect to from the list available Wi-Fi networks.
4. Enter the case-sensitive password to connect to a secured network. Your phone will only prompt you to enter a password if connecting to a secured network.
5. Wait while your phone automatically connects to the Wi-Fi router.
and enjoy your wi-fi connection.
2answers
Can't access to internet connection...though it has wifi signal
Yup its have a wifi signal. But you need a wifi router .like mall they have a free wifi or a computer shop. If you want to open your wifi just 12 click menu-setting-connectivity-WLAN-on your wifi then search.then click the available wifi then if say connected.. You can now internet..
I got wifi connection in several places, but why, when I turn off the 3G connection from the cellphone provider, I cannot use the internet connection I got from wifi. What do I need to change in the...
These days each WI FI connection has a password which you have to feed to gwt connected to that particular WI FI connection. So please get the password if you want to get hooked to a particular WI FI. You cannot get connected to any Wi Fi.
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
