SOURCE: No power produced by All Power America 3500 Watt Generator
see if the breakers have been reset.
SOURCE: 5500 generator stopped producing eletric after
First check with the
dealer and see if it is still under warranty. If it is not, make sure nothing
is blocking the air flow around where the control modules are located. This
could cause the voltage regulator and other electronic parts to overheat. Next
check the brushes and make sure they are free of any dust or build up preventing
them from making contact.
If everything is OK the
next thing I would do is change the voltage regulator.
SOURCE: Brand new B&S 5000 watts
There really is not much you can do without voiding your warranty. This may be something simple like a connector that vibrated loose inside the control panel. (Alternator to contol panel inter-connect) There could also be a wire lying loose that was not connected. Open the control panel... and look for anything obviously out of place. DO NOT do anything else. After that your stuck with the warranty process of Briggs and Stratton.
http://www.briggsandstratton.com/~/media/PDF/BriggsStratton/Engine_Warranty.ashx
or 1-800-233-3723
When your at a B & S service / repair point... (store front)
Things to note .
1. Tell servicer unit is for PRIVATE USE (There is no warranty for commercial use)
2. Have proof of purchase in hand otherwise they will use the MFG date as the start point of the warranty. Many generators sit in a warehouse or on the shelf long past an implied warranty (date of mfg) Bottom line you need to have your sales slip.
There are several things I could have you do but... as the consumer the only thing you can do is perform an inspection. By opening the control panel you need to tell the servicer the only thing you did was a VISUAL Inspection...... Anything else will void your warranty.
So.. look for any obviously loose parts or or connectors. After that sadly your stuck with dealing with warranty service.
Thanks for choosing FixYa,
Kelly
