Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
The presence of a red light on the printer can indicate different things depending on its behavior and the specific model. Here are some common reasons for a red light on the Samsung ML-1860:
Error or Issue: If the red light is solid or blinking, it might indicate an error or issue with the printer. This could be related to a paper jam, low toner, a cover not properly closed, or any other hardware problem.
Low Toner: In some cases, a red light might indicate that the printer's toner is running low or needs to be replaced. Check the printer's control panel or software utility for any low toner warnings.
Printer Offline: If the red light is on, and the printer is not responding to print commands, it might be offline or not properly connected to the computer or network.
General Status Indicator: Some printers have a red light that serves as a general status indicator. This light might be on during normal printer operation and is not necessarily indicating an error.
To determine the specific reason for the red light on your Samsung ML-1860 printer, follow these steps:
Check Printer Display: If your printer has a display panel, check if any error messages or warnings are displayed. The display can provide valuable information about the printer's status.
Check the User Manual: Refer to the printer's user manual or documentation for information about the meaning of the red light and troubleshooting steps.
Inspect Printer: Physically inspect the printer for any paper jams, open covers, or other visible issues that might be causing the red light.
Check Toner Level: Check the printer's control panel or software utility to see if the toner level is low or depleted. If necessary, replace the toner cartridge with a new one.
Ensure Connectivity: If the printer is connected to a computer or network, ensure that the connections are secure, and the printer is set to "online" mode.
Restart Printer: Try restarting the printer by turning it off and unplugging it from the power source. Wait for a minute, then plug it back in and turn it on again
You need the device driver so that Windows can communicate with the printer. Try the Samsung website and look for Drivers for the ML 1610. Or try running Microsoft Update.
see, you have inserted the paper well. if not solved, your catridge have low ink or empty. so bring a new catridge or if you can, refill the catridge. 1610 catridge can be easily refilled.
please your problem is printer in rem and sarket in ice is fail. and you go to the near autho. dealer and changing the serket board
and checked the rem. and printer's services is fine.
There would be two things to ensure Vista compatibility of the Samsung ML-1610. 1. Download and install Vista update/patch for USB core components here and/or here; 2. Download and install Vista compatible Samsung ML-1610 drivers here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
