Question about Razor Toys
How do I put together a. Taken apart razor scooter
SOURCE:
  • 18 Answers
SOURCE: paintall gun is taken apart and i need to put it
There are pdf manuals on the Tippmann website.
http://www.tippmann.com/usa/cust_service/manuals.aspx
Posted on Sep 30, 2009
harlan301
  • 205 Answers
SOURCE: I have a powercat airbrush and the gun has been taken apart
ill need model and ser for the unit. thank you
Posted on Oct 24, 2009
brector3
  • 1636 Answers
SOURCE: I have a Philips Norelco
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Posted on Sep 19, 2010
  • 48 Answers
SOURCE: Need instructions on how to put it together again.
send me your fax number so i will send manual
Posted on Nov 23, 2010
brector3
  • 1636 Answers
SOURCE: Someone at home decided to
See tutorial video on this at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
Posted on May 09, 2011
Tip
AVOID RAZOR SCOOTERS BUY VESPA OR HONDA SCOOTERS. THEY LAST FOREVER.
Avoid razor scooters. I bought one at the goodwill thinking what a deal ... After new bats and wiring still no working. I got taken for a ride alright !
Bought a Vespa and it works beautifully. Hondas are great too. Kids ride very summer. All summer same scooters . Razor is a scam.
on Feb 06, 2014 | Razor E300 Scooter
Problem putting the brake together on razor e300
The brake adjustment is covered on page 5 of the user manual. There are photos of various band brakes here http://www.electricscooterparts.com/bandbrakes.html
What part of the band brake are you having and issue with?
Aug 14, 2014 | Razor E300 Scooter
2007 chua scooter
Hi Bryan, for more information about your question please visit the website below. Good luck and have a nice day.
Scooter Service And Repair Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 17, 2013 | Motorcycles
Razor e300 needs to be continually reset
Sorry it is really important to get your scooter put together and charged right away or it will get ruined Need new batteries
Nov 12, 2011 | Razor E300 Scooter
Its apart
Click the link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to page ten, it has a full exploded diagram of the scooter.
Aug 09, 2010 | Razor E100 Electric Scooter
I have the little gem 4 and its been in the garage over the winter as i've not been out, i took it out today & it wont work when i turn the key there is a constant beeping, i have taken it apart &...
hi, the rear connections to the main frame are a big cause for problems , make sure the contact are clean and there is a actual connection.
Also check the free wheel lever.
Also you may note that if you haven't charged the batteries for a while , they get weak and may need replacing.
Regards
GeWiz.
Feb 01, 2010 | Drive Medical Mini Phantom Three Wheel...
My son rode his E100 scooter through a puddle and didn't tell me until a few days later. The scooter won't turn on now and I've tried to re-charge the battery. Is there anywhere I can send this scooter for...
Your problem could be one of two things. The motor could have short circuit or the components under the deck could have short circuit. The problem is, when your son ran the scooter through the puddle the water acted like a conductor. Connecting the positive and negative poles together until the water dried out(creating a short circuit). I suggest, if you're handy, to take the deck off and check for corrosion both the battery and the controller. If that's not the problem then check the motor (you're probably going to have to take it apart). Just a quick tip, be aware of everything you apart. Where it goes and how fits on there. It will make it a lot easier to put back together. Once you find the problem replace the part either by finding the replacement at razor.com or at electricscooterparts.com. If you not handy then send the scooter to razor for repair, but it might take a while to get back. Best luck.
Oct 16, 2009 | Razor E100 Electric Scooter
WHERE CAN I GET DEMINSIONS FOR A PRO RAZOR SCOOTER. IS THERE A WEBSITE I WANT TO MAKE ONE IM MY METALS CLASS. IM IN DRAFTING ONE SO I WANT TO GET THE DIMENSIONS AND PUT IT ON THE CAD SYSTEM.
Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
  • Razor Pro Model Scooter has a double stacked head clamp for extra head tube strength and the scooter is made from aircraft grade aluminum.
  • It has a full deck and 98mm urethane wheels equipped with ABEC-5 high speed bearings.
  • Razor Pro Model Scooter folds for easy storage and transport.
  • It can hold riders up to 220lbs.
  • Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
Sep 23, 2009 | Razor Pro Model Kick Scooter Fun Kid...
Toys Logo
62 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
