A relative accidentally pulled the planetary off of our kitchenaid Pro mixer. It appears that the planetary has separated from he main shaft and that the main shaft is still attached in the mixer. The motor still works andthe shaft spins. Do I need to order a new planetary and shaft or is there a way to reattach it? It seems like all the parts are there it just needs to be pushed in place. Is that correct? It all fits together but I was having a hard time pushing the shaft back into the planetary is there a good way to do this without damaging it or the gear? Please help!
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
SOURCE: Where can I order parts for my kitchenaid pro 600?
mendingshed.com sells a lot of internals for those machines
SOURCE: repairing a kitchenaid 6qt mixer
Hi. Go to the whirlpool.com website, for some insane reason they don't list their mixers, enter a search for mixers, then find your model #. Look for a parts catalog. Look at the "exploded" drawings for the transmission area. There you'll notice that there are Front and Rear bearing locations. This drawing also shows the correct place for the "washer". Also, the front and back bearings may look alike, but the're not. Every part needs to be in it's correct place or damage will occur when you start it up, or when you place the machine under load. Let me guess...The original PLASTIC transmission housing broke causing damage to the worm gear assembly. If this is the case, your replacement transmission housing should be made out of metal. If it isn't, call customer service and demand that they send one. The plastic housing has no place in a Premium priced mixer, especially when they advertise that the mixer can handle heavy bread dough. Finally, check the bearing seats, when the worm gear failed it may have also damaged these seats. It happened on my Kitchenaid. Good Luck!
ricardok45
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
SOURCE: Kitchenaid mixer starts smelling electrically hot after seconds
Hi. Go to mendingshed.com. Click on the Kitchenaid product button, then click on Kitchenaid parts. At the top of this page locate the Adobe Icon near the top, click on this file and download the free Kitchenaid Service Manual. This manual will assist you greatly with your mixer's electrical circuitry and anything else that needs repair.
Mending Shed also sells Kitchenaid parts. Good luck!
