Lorex SG19LD804-161 Logo
Picture is blurry on monitor whitish fog all over. please assist
Blurry!! how do I fix it? is there a way to set it to default?
For beat picture, the PC video resolution should be set to 1280 x 1024 @60Hz, please try setting out.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
2helpful
My Acer AL2216W suddenly displays a blurred picture. I turned my computer off at night and in the morning after running a virus scan the picture comes in blurry. How do I fix this. I've rebooted several...
Please verify that you are running your PC video card with native resolution of this monitor, 1680x1050 @60Hz for best picture for this monitor.
Unless you may have problem inside the monitor or the video card itself, so try this monitor on another PC also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Washed out (whitish) picture on most settings - especially compared with our great Samsung 50" plasma in the adjacent room
Try playing with the settings on the "secret menu".
To access the secret menu turn of the monitor, and press:
info -> menu -> mute -> power on
Blurry picture
With the back off and if you can get a small mirror above the blue and the green tube, look at the picture coming out of the tube. If it looks like you're looking through fog then you probably have contaminated coolant. Compare them to the red tube for reference because the red one is very seldom affected.
If contaminated, the fluid will have to be changed and the chamber cleaned out by someone that knows what they are doing.
Be careful reaching in there. Wear gloves to help protect your hands.
Sony T5 is flashing Error E91:01 and the pictures are blurry
My Sony cam was woring fine but suddenly it started giving an error E91:01 which is continuously flashing
Blurry tv monitor
try to adj picture settings.
Blurry image on screen!!!!
you might to check that the phone has not been exposed to water fr a long time, also inspect if the camera lens is cracked or fogged up
1helpful
Screen becomes unviewable
Sounds like a problem with the graphics card or on board video. Please state which one you have and type. The last option is a bad monitor. Try Degaussing it first on the monitors menu selections. If you use a graphics card, you can disable it and try the on board one to see if it helps. If you need further assistance, please ask. I can guide you through all the steps.
Top Lorex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Lorex Televison and Video Expert? Answer questions, earn points and help others
