HP LaserJet 1200 Printer Logo
K
Kristinn Hilmarsson Posted on Dec 17, 2015
The printer in error state
The Active Directory Domain Services is Currently unavailable
1 Related Answer
Anonymous
  • 1197 Answers
  • Posted on May 01, 2009
SOURCE: unable to print from laptop to HP Photosmart C3188
Did you try adding the printer using Administrator privs? Just go to the Control Panel > Printers > Run As Administrator > Add Printer. This process gave me access to the network printer. Unfortunately, MS Word will not work at all if the network printer is setup as the default and not added by the administrator.
Why can't I connect my printer to my desktop?
It sounds like you are trying to connect wirelessly.
Have you reset the printer settings?
Also the printer software needs to be loaded.
If you do not have the disk, go to: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3390949&
choose your operating system and download the complete software package.
Hook up the printer by cable and install the software (follow the instructions the install gives).
Also, if the printer was hooked up in a network, you will have to reset the network information on the printer. The HP site above has instructions and manuals that can be downloaded.
When I press find printer on my epson-312 it says "the Active Directry services is currently unavailable
Reinstall your printer software if you do not have the disk the manufacture of the printer usually has the software of your model on there site
Directory services restore modesafe
Start, Run "services.msc"
Right click on Active Directory Domain Service, Left on Start.
If Started then Smile. If Not Started then Read Error Message.
SIR I AGAIN ASK THAT I USE TO NEW HP DESKTOP PC WHEN I LOAD ANY PRINTER THAT TIME THE MESSAGE IS THAT "THE ACTIVE DIRECTORY DOMAIN SERVICE IS CURRENTLY UNAVAILABLE"
you must contact to printer supplier what going on? You will get via ONLINE chat free, and resolve inmediately.
God bless you
2helpful
Unable to print from laptop to HP Photosmart C3188
1helpful
My computer can't "find" a printer, even though is installed..
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Domain controller error
First reboot once your PC and if that does not work then:
when you login with your local admin account are you able to ping the DC? Also, check the IP settings to make sure they are correct. Are you using DHCP or are you static? If you are able to ping the DC adn IP settings are correct, is the computer name in Active directory? Also if the computer name is in active directory, is it disabled? If you check all these things and you are still having issues, drop the computer from the domain, rename it and create the new name in Active Directory and then add the computer back to the Domain. Somewhere along the line of following these steps, you should get the computer back inline. If other computers are able to connect to the domain then it is definitly an issue with this computer name or a setting on this computer.
Thanks
Note: do not forget to rate the answer.
2helpful
4answers
DNS
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
1helpful
Backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
k24674
Grand Canyon Tech
Grand Canyon Tech
