Hello labdes,
The "remote" terminal of the amp requires a +12V signal to rurn the amp on. Normally, this is supplied by a specific wire from the vehicle "head unit". But you can simply jumper it to the positive 12V source. + should go to the 12V positive and to "remote", - to the 12V negative. I'd wire a switch across the "remote" and "power" terminals to have a way to turn the amp on and off.
I'm hoping that your "car amp" has speaker level inputs, because the PC card is probably not going to have preamp outputs. If the amp has only RCA type inputs, you will need to purchase a LOC (line output converter) such as the
PAC SNI-35 shown here. They are also usually available at your local car audio shop and some big box stores.
Hope this helps.
