Monster Beat Box By Dr Dre iPod Docking Station Logo
Carlton Garcia Posted on Dec 16, 2015
Why does it keep cutting off?
When I touch the power button it comes on then cuts off after about five seconds
Fridged cuts out
hi Joseph! your refigerator may have run out from coolant ,and the main reason to open and close is because it has a safety switch.
3helpful
Stops working after 20 seconds
The magnetron is over heating causing the thermal fuse to open to cut power, the only option is replace the part, but keep in mind it is the most expensive item to install.
1helpful
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
HOW DOES THE KNIFE GETS ALIGN SO IT WILL CUT?
You have to tell it to cut. Your software has to know there is a knife attached to the printer, so it will know to cut. You have to program it to cut, -where and how you want it to cut your supplies.
Press the feed/cut button and hold for five seconds. It should feed and then cut your supplies - this will tell you whether the knife is working and if it's cutting straight.
Dr-bt21g ipod touch cuts out
Bluetooth?
This is a new BETA function to the iPod Touch 2G and 3G.
9helpful
2answers
It frozen. It will not cut on or off. If I plug
There is a tiny reset button right next to the USB data/charge port.
Tv turns on then off
check the power supply for bad capacitors if they are good, replace the power supply board
good luck
1helpful
Apps that cut off
Try rebooting your iPod touch by holding down both the sleep/wake and home buttons at the same time for 10 seconds. Should come back with an Apple logo.
The reason for this is that your iPod, like a computer, can start to run low on memory.
Another solution is, if you recently upgraded to OS 3.0, some applications might not be compatible yet. You can either wait for an update from the developer, or check if there's any current updates for the apps that don't open.
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 • Home
Top Monster Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Monster Televison and Video Expert? Answer questions, earn points and help others
