Question about Precor C966i Treadmill C 966i
We only get a STOP KEY and it will not run - Precor C966i Treadmill C 966i
    New Friend:
C966 have Precor transported from one place to another place is not rash to give any signal in transcri could you help
Posted on Apr 23, 2016
SOURCE:
Toyota avolon wont stop running when you turn the key off
This is known as 'dieseling'. The most common causes are
-idle speed set too high
-engine operating too hot (faulty thermostat, faulty temp sender, leaky head gasket)
engine timing is out (loose distributor clamp, worn timing belt, faulty timing belt tensioner)
Jul 19, 2016 | 1998 Toyota Avalon
Reprogram the computer so the key works I tried to jump starter with screwdriver it would run for A second then stop when turn key it does nothing
no your antitheif is workin property if you jump starter and the engine cut of is because the system is working thry jump start whit the key on the ignition on the runn position is goint to be running and dont stop
Oct 01, 2014 | 2000 Chevrolet Impala
The term immobilize is on the display panel and I want to start it up. How do I get it going again?
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill Fitness...
My precor c954i displays message STOP KEY and will not run? How come?
1) adjust the reed swithc, clean , and tigh the wire connectors very well
2) run the software calibration for diagnostic and troubleshooting.
God bless you
Jun 19, 2012 | Precor C954i Commercial Treadmill
The remote on the key is soaked. will this stop it from running
Get your wife of girlfriends hair dryer and dry it out , or is that too easy !!
Dec 25, 2009 | 2004 Pontiac GTO
The treadmill does not incline. Motor runs when the button is pushed but no movement.
Try Re-Calibrating 1st, here's how.
With the Treadmill off, press and HOLD the SPEED UP & STOP
keys, while holding the speed up & stop keys insert the Safety key (Magnet) release the speed up & stop keys. now press and release the stop key. now press the "incline up key" let the treadmill go to max incline,after it stops press and hold the "incline down key" let it go to minimum (completely lowered) you should now be re-calibrated.
Dec 23, 2009 | Epic 425 Mx Treadmill EPTL88105 !
Error code=620
Hello sir; Follow the following steps to reset;
1, press these three keys in order and keep hold them down,"stop/reset", "start", "left copy density key".
2, press "stop/reset" key again.
3, enter 163, then press start key,
4, after they running, press "stop/reset" key.
5, press 001 to exit.
Mar 15, 2009 | Copystar CS-1505 Copier
Ignition alarm will not stop 97 ford f150
The key switch usually breaks or wears out and makes contact. It is on the lock cylinder. This would cause the chime to not come on, or stay on. Sounds like the switch is bad.
1997 F-150/250 Warning Chime, Key-In-Ignition The key-in-ignition chime warns that the key is still in the ignition when the driver's door is ajar. The key-in-ignition warning chime will sound when:
  • GEM: Driver door is ajar, the ignition switch is in the OFF/LOCK or ACC position and the keys are in the ignition.
  • CTM: Driver door is ajar, the ignition switch is in the OFF/LOCK, ACC or RUN position and the keys are in the ignition.
The key-in-ignition warning chime will stop sounding when:
  • Driver door is closed.
  • Key is removed from the ignition.
  • GEM: Ignition switch is switched to the RUN position.
The key-in-ignition warning chime inputs are:
  • Ignition switch RUN position (battery potential on both RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on RUN/ACC input only).
  • Key-in-ignition switch (grounded with key-in-ignition, open circuit with key-out).
  • LH door ajar switch (open circuit with door closed, grounded with door ajar).
This is a pic for a 98, could not find one for 97 which may be the older style which is more prone to break.
Feb 14, 2009 | 1998 Ford F150 Regular Cab
RELAYS
hi if you mean every time you stop the car by key and the car will only keep going if the key is in the start position this is a fault that lies in the low tension circiut on your ignition as a secondary circiut with a ballast resistor runs ignition live feed to the coil when the key is in start position these are now normally in the ignition coil it will need replacing
Oct 01, 2008 | 2007 Buick Park Avenue
Precor C966i Treadmill C 966i Logo
136 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
