Televison & Video Logo
d
dorothy jorgensen Posted on Dec 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power adapter DC 4.5V AC 600ma - Durabrand Televison & Video
Bill Boyd
Level 3:
Top Expert:
  • Durabrand Master 53,816 Answers
  • Posted on Dec 15, 2015
Bill Boyd
Durabrand Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949594
Points
172802
If you want one ( gathered from your statement) try Jaycar or other electronic supply shop
1helpful
2answers
Trying to figure out what kind of AC adapter to get for a Panasonic TRG-513T TV. Can't upload user manual. I see it requires 9.8 v, but what amperage?
the back says "DC 9.8V 5.8W"
Amps * Volts = Watts. thus Watts / Volts = Amps
9.8 / 9.8 = .5918 Amps.
rounded 600mA
but I'd suggest a 1A
tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 • Cameras
Microsoft Cpa09-010a Ac Adapter Xbox360 Slim 135w stopped working
if your volt is 220v. so you can use fuse on AC line 600mA to under 1Amp.
DC line fuse is under 12Amp. clean any power cable port & use perfect gas.
9helpful
4answers
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
I just need a power supply cord to charge my jump starter system. Where can I get one?
Just get a generic charger from EBay. They may be available elsewhere. Get a 12 volt 500-600 milliamp one or if you know the exact milliamps for your charger, use that number. Here's a link to one on EBay.
http://cgi.ebay.com/12-VOLT-AC-POWER-SUPPLY-ADAPTER-12V-DC-600MA-CHARGER_W0QQitemZ300404845865QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f1862d29
I'm not recommending this particular one, just using it as an example. Good luck!
Can I use a PowerLine universal ac adapter 3 12 volts DC/600ma to power Acer Travelmate 2300 series
No. It is rated at 600 MA which is way too small. The acer needs a 60 watt adapter. Please search online for the best price and get the proper adapter. About $40.00
HOW MUCH VOLTAGE SUPPLY NEED TO RUN ALTEC LANSING BX1020
i supply my BX1020 speaker system with a 9 volt DC power and 600mA of current . i use a wall adapter or "wall wort" i bought from walmart .its an adjustable voltage, that you choose with the switch. the amperage is set & not adjustable. i used to hook these speakers with an "aux" cable to my phone to listen to music, when friends came over. the 9volts supplied was plenty enough power to make these speakers Loud ! i am now gonna convert these speakers into an amplifier for my CBG . i literally just powered it up and turned it on. to be sure my answer was correct. i have them dissassembled and out of the housings, on my work bench. 9volts DC & 600mA
1helpful
Missing power supply
Output of Factory AC/DC Adaptor: 5.6V DC  600mA
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
