SOURCE: 2002 Explorer Gear Shift stuck
Start with the brake switch because that is what controls the part lock solenoid. The odds that both the lock solenoid and the brake switch went bad is negligible.
Hope this helps
SOURCE: gear shift will not move . button on gear shift
connection under shifting housing, broken??
there is a release button there as well will bypass the connection
The automatic transmission shift lock control switch
The brake to shift relay
The rear integration module (RIM)
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
