Make sure the on and off indicators are approximately an hour away from the current time you wish to set the timer to. Using your thumb and one of your fingers (ring, index or middle) grasp the edge of the yellow time indicator. Pull the time indicator straight out away from the back of the unit. While the time indicator is pulled out rotate the wheel to the correct time in reference to the time pointer. Release the time indicator and set the on and off indicators to the desired times in reference to the time printed on the time indicator. Manually move the bottom switch to on or off state which the timer should be at the current time. If you do not see the time wheel move after approximately 30 minutes the timer could be defective.
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Rotate the time dial clockwise at least one click, stopping at
the half hour nearest to the present time.
NOTE: During programming, be careful not to press the
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
Press the dial once to set the present time. The Red indicator
light will go off.
Rotate the time dial clockwise to the first desired ON time.
The Red light will pulse momentarily with each click.
Press the dial once to enter the ON time. The light controlled
by the switch timer will turn ON.
Rotate the time dial clockwise to the desired OFF time.
Press the dial once to enter the OFF time. The light controlled
by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting.
Continue to rotate the time dial until the Red indicator light
comes ON and stays ON, indicating that the switch timer is in
AUTOMATIC mode.
