Bizhub c652
Noise and jamming to different for the noise fuser unit replacement, for the jam where does it say the paper is at???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
SOURCE: We have a Konica Minolta C652, scanning books to pdf
Hi Potahal,
You can do it straight from the photocopier by using the "Seperate pages" button/option. Then you just keep scanning page after page and chose "Finish" to build all the seperate pages into one pdf.
SOURCE: Konica Minolta C652 Fax/Scan Button and User Box Button
The hard drive is not turned on. enter service mode ( utility, meter count, details, stop, 0, 0, stop, 0, 1 - this should be pressed in exact succession) then go to system 2 and look for a place where it asks you about all the installed perifferals. Turn the hard drive setting on.
SOURCE: Konica Minolta bizhub 180 printer
Open all covers and clean again. Look for small piece of paper somewhere on paper path.
SOURCE: my printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if
the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in
the paper tray, the jam clear cover located in the back of the machine,
is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
