Computers & Internet Logo
Kayvee Gee Posted on Dec 14, 2015
Dragon naturally speaking for free
Where can I get this free
Dragon Naturally Speaking Playback is not working with Word document.
This link would better explain your issue and has the best solution.
Ihope that will fix the issue...
Dragon Naturally Speaking Playback is not working in Word document
2answers
Can I use Dragon Naturally Speaking in languages other than English?
Yes you can use Dragon in over 79 different languages! You can find this list here on their website.
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
I just bought naturakl speaking 11.5 home. how do i download it/
Dragon Naturally Speaking 11.5 FULL
If you already have a premium key,
Click here
Dragon Naturaly speaking XP editions not finding audio and video cards
and we can assume your computer is running xp correct? If not, then you'll need the updated Dragon, naturally speaking
Trying to use the headset provided by Dragon 11 naturally speaking software. The headset has two jacks, a mic and a headphone one which I have set up via RealTek, although I cannot get playback on the...
Did you check the installed sound devices on the computer?
May be you do not have any sound driver installed on the computer,
Also check the device is not disabled from the control panel.
If you did not find the solution helpful. Try to search for the solution here... this has many solution to this problem.
Nuance and Dragon Naturally Speaking Support
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
1helpful
1helpful
2answers
I need a softwar that can take notes through my headphone mic word/text
Alright, well you have many options to choose from.
If cost is an issue, you can try this free application:
http://www.e-speaking.com/free_voice_dictation_software.htm
However, if performance and quality are crucial, I would suggest going with some more esstemed products.
Products such as Nuance's Dragon Naturally Speaking:
http://www.nuance.com/naturallyspeaking/
Or a product from a company called VoiceBox:http://www.voicebox.com/
Also, try Downloads.com and see what you can find, if your not fully satisfied with the free link.
Let us know.
Top e-Speaking Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an e-Speaking Computer and Internet Expert? Answer questions, earn points and help others
