Kodak EasyShare C613 Digital Camera Logo
Albert Caka Posted on Dec 13, 2015
How do I get camera to work, or is it no good anymore?
Batteries died. Lense was in out position. Put new batteries in, & will not do anything.
mosack
Level 1:
  • Contributor 36 Answers
  • Posted on Dec 13, 2015
mosack
Contributor
Level 1:
Answers
36
Questions
0
Helped
14093
Points
52
Sometimes, when the batteries die, it kills the internal computer. It happened to one of my cameras as well. The cost to have the new computer installed was about $230.00. I took mine to the local professional comouter repair shop and it was returned to me in less than 24 hours and working great. Your price will vary the make, model of camera. Mine was a Canon 5D mk2. Take it there and let them give you the diagnosis and then decide if it's worth it to repair or replace it. Don't use my fee as your guide, unless you have the same camera.
Hope this helps. Mike
I put new batteries in my camera-but doesnt do anything. I left camera on,I think and then thought batteries died so then replaced with new ones.now nothing works.
This happened to me as well. I took the batteries out and put new ones in three times (same batteries). The third time the camera started working again as soon as I closed the battery compartment and tried on "on" button.
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1helpful
Lens keep extended in an out
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
2answers
Optical lense stuck in the "out" position
when i dropped my dx7630, a tiny plastic part broke that worked the holdback spring for the battery. Kodak has a repair service, or a referral service for repairs, but you have to send the camera in. i sent it in. they emailed me to say it was not a repairable part and didn't even ask if i wanted it back. luckily, i kept the memory chip. the C875 i bought was $100 cheaper and had 1M more pixels. good luck with your natural light photography from now on. i think Kodak just figures you buy a new camera whenever anything goes wrong, it'll be better and cheaper anyway.
Camera
hmmmm? try diffent new set of battiers I found bad brand new batteries before. also notice the + and - (- is bottom of battery) and make sure bat. door is snugly closed. other than that your camera just broke down. Murphy's law good luck
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
