I NEED HELP WHAT MUST I DO?I have a HE5 KENMORE DRYER THAT I BOUGHT AT SEARS AND THE POWER LIGHT COMES ON BUT IT WILL NOW POWER ON SEARS TECH SAID IT WAS THE INNER FACE BOARDS SO I REPLACED THEM MYSELF CORRECTLY PER ANOTHER HOME TECH REPAIRMAN.. BUT THE DRYER STILL WILL NOT POWER ON, WE CHECKED THE THERMAL FUSE AND ITS GOOD.. WHAT SHOULD I DO? I LOVE MY MATCHING WACHER AND DRYER SET AND DONT WANT TO REPLACE IT? PLEASE ADVISE
SOURCE: need to replace thermal fuse on kenmore dryer 110.75924401
This fuse is located on the back on the wind tunnel exhaust.
SOURCE: kenmore elite oasis washer
Today (4/3/09) I got a letter from Sears. They will replace the electronic control board (you know, the F-51 business) for FREE, in warranty or not. Serial #s for the Bad Board begin: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083. The voices of all of us have finally been heard! There is a class action attorney firm in San Francisco looking into a legal remedy.
SOURCE: My clothes smell musty after they have been
The filter on your pump is probably clogged with lint and
stuff. You have to remove the bottom front panel, 3 torx screws
underneath. The
panel will drop and come off. Drain off the excess water from the hose
you
see. The white filter cover is right in front.
Get yourself a bunch of towels or a good big plastic bag to collect
water.
Unscrew the filter cover and twist the filter out. Clean out all the
stuff and
put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits
of soap and other such things can be
stuck around the inside tub of your washer. Try this product, it works
great on
all front loaders. Use quite hot water with the Affresh pellet with no clothes
and
run the machine through a cycle. Also
helps with any stagnant water smells. Have you cleaned out your pump
lately. Put the pellet inside the
machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
SOURCE: kenmore elite dryer 110 8772 He5 lights up, will
MANUAL DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
-Close the door.
-Select any one key (except STOP) and follow the steps below, using the same key (remember the key):
Press/hold 4 sec's.
Release for 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's., release
NOTES:
-Press the same key to advance to the next failure code.
-At the end of the procedure the program will loop back to the beginning. This is a continuous loop.
-To cancel out of the Manual Test Mode press STOP.
Exit Condition Control Action To be Checked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
