Car Audio & Video Logo
greg Posted on Dec 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you set and turn clock display on naxa nx667
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 13, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067198
Points
28436
Naxa Electronics NX-667 Clock setting - Questions - Fixya
www.fixya.com > ... > Naxa Electronics > Naxa Electronics NX-667
Naxa Electronics NX-667, clock setting related issues. ... set up the clock time 1: press Source button to turn off unit 2: press Clock button to display clock 3: press ...
Naxa Electronics NX-667 Kd s35 manual - Questions - Fixya
...kd-s35 Press and hold SEL button. Press ^ button 3 times to display H (hour) turnvolume knob to change hour setting, press down 1 time to select M (minute) ...
General FAQs - Naxa.com
How to change the time on a Naxa NCR-175 clock radio
The manual explains
cd radio clock - model nrc-175 - Naxa Electronics
Naxa Electronics https://naxa.com > NRC-175_English_Manual PDF manual. The user could lose the authority to operate this equipment if an unauthorized change or modification is made. SURGE PROTECTORS:.
NAXA NDL 254 no sound on tv
If your NAXA NDL 254 is not producing sound on the TV, but the DVD player and radio have sound, then the issue is likely related to the connection between the NAXA NDL 254 and the TV. Here are a few troubleshooting steps you can try:
  1. Check the audio cables: Make sure the audio cables are securely plugged into both the NAXA NDL 254 and the TV. If the cables are loose, they can cause a connection issue and prevent sound from being transmitted.
  2. Check the TV audio settings: Check the audio settings on your TV to make sure that the correct audio input is selected. If the wrong input is selected, you won't be able to hear any sound from the NAXA NDL 254.
  3. Check the NAXA NDL 254 audio settings: Check the audio settings on the NAXA NDL 254 to make sure that the volume is turned up and that the correct audio output is selected. If the output is set to the wrong channel, you won't be able to hear any sound on the TV.
  4. Try a different audio cable: If you're still not getting any sound, try using a different audio cable to connect the NAXA NDL 254 to the TV. A faulty cable can prevent sound from being transmitted properly.
  5. Try a different input on the TV: Try plugging the NAXA NDL 254 into a different audio input on the TV to see if the problem is with the input you're using.
If none of these steps resolve the issue, it's possible that there's a problem with the audio output on the NAXA NDL 254 itself. In that case, you may need to contact NAXA customer support for further assistance.
1helpful
Where can I find naxa nrc 175 owners manual
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.naxa.com/downloads/NRC-175_English_Manual.pdf&ved=0ahUKEwifiMHTpu3SAhVG8mMKHWbYAaYQFgiIATAA&usg=AFQjCNHsACXhXz4NtotSubeJGjweiXoTVg&sig2=e3OdhLZr4y21AJ7QJvSGrw
9helpful
2answers
I HAVE A NAXA NX-671 AND CAN'T FIGURE OUT HOW TO SET THE CLOCK
I got a 671 from jujudeals.com and the exact same thing happened. When I talked to them, they said to first, go into clock mode. While you're in clock mode, press and hold select (SEL). Still holding select, use the Fast Forward and Reverse buttons to change the time. FF will change the hour, REV will change the minute. Hope that helps, and if not, you can contact the Naxa support people at this page:
http://www.naxa.com/newsite/support.html
1helpful
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
23helpful
2answers
How to set the clock on the car stereo (Naxa nx-670)
I had the same issue. I bought my 671 mp3 car stereo from jujudeals.com and I was having the same problem. I called them up and they said that I have to go to clock mode. When in 'Clock Mode' you have to press and hold Select (SEL) and at the same time press FF/REV to adjust time. (Fast Forward adjusts hour, Rewind adjusts minute). If your still having problems contact the Naxa Electronics warranty department. Goodluck!
1helpful
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
display appears on the display.
on or off.
on or off.
Have Pioneer DEH 1900MP CD receiver. Do not know how to set time. Have no amnual. Also information on the remote control
It's on page 12 of the manual. Here you go:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/372010482DEH1900MPOperationManual1030.pdf
from this unit.
turns off.
settings.
particular setting.
Setting the clock
clock display:
Hour—Minute
on or off.
on or off.
Operating this unit
12 En
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
