It sounds like you may be hearing a noise coming from your vehicle's locking system, which is likely the Locktronics box. It is possible that the noise you are hearing is a normal function of the Locktronics system, especially if it sounds like a beeping or clicking noise.
Locktronics systems use a series of solenoids and relays to lock and unlock the doors, and this process can sometimes create a clicking or beeping noise. This noise can be more pronounced in certain vehicle models or aftermarket installations.
However, it is also possible that the noise you are hearing is caused by an issue with the Locktronics system, such as a malfunctioning relay or solenoid. If the noise is accompanied by other symptoms, such as difficulty locking or unlocking the doors, or if the noise is very loud and persistent, it may be best to have the system checked by a professional.
If the noise is coming from under the dash, it could be the actuator motor, which is responsible for the lock and unlock function, making noise. It's best to diagnose the problem by a professional or contact the manufacturer for assistance.
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
Hi Charlie, thank you for allowing me to assist you!
Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become common to you. This also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable. If the noise, however, become louder or more pronounced, then you may want to connect with a local appliance technician to determine if anything else may be the cause.
Good Afternoon frnk, thank you for allowing me to assist
you!
The click you hear when you activiate the joystick is the electric solenoid on the automatic brakes going on, and then off when you push then release the joystick. This is normal. If it isn't moving, check to see if the free-wheel levers are in gear or in neutral. If you can push the chair, you are in neutral and activating the joystick will just release the brake and run the motors. Turn the two levers to the drive position and then it should take you where you want to go.
