Question about Little Tikes DiscoverSounds Sports Center Colors/Styles Vary
Need basketballs - Little Tikes DiscoverSounds Sports Center Colors/Styles Vary
Need instruction manual
http://www.instructionsmanuals.com/
Feb 14, 2016 | Spalding Basketball Spalding NBA 66349...
I have a Spalding 60 inch glass basketball system. It was lowered all the way down and now it can't be raised because it's too low. How do I fix this?
In-ground Basketball Goals: Spalding 88369 NBA ...
www.atlantahoops.com > In-Ground Basketball Goals
The Spalding 88369 NBA Inground Basketball Goal System includes a 60'W x 36'H Pro style extruded aluminum framed Tempered Glass or Acrylic backboard ... Click here to download the Spalding 88369 Basketball Goal Owner's Manual
Jul 26, 2015 | Spalding 79307 Basketball Backboard and...
How should I clean my basketball uniform?
You should wash it on a regular cycle. It does not to be gentle because the fabric can take a lot of pressure and sometimes need it. You can even put the detergent directly on certain spots to get rid of stains. I just suggest that you don't use bleach and that you use cold water so that the colors don't run.
Feb 06, 2013 | Basketball
I need a instructions on a lifetime portable basketball goal that i can praint out
Here is a link to the manual you are looking for. I found it on the manufacturer's official site.
Jan 29, 2013 | Project Runway Lifetime 48" Portable...
How to pump up a basketball?
To watch an instructional video follow this link http://youtu.be/WnU8XSEhfCU or read the instructions below.
To pump up your basketball you will need a ball needle and a hand pump. Insert needle and pump the ball to the specs listed below.According to NBA rules, the pressure inside a basketball must be between 7.5 and 8.5 lbs. You can use this as a guide for your own basketball pressure. Another simple test is to drop the ball from shoulder height. It should bounce to a height approximately even with your hips. When inflating the ball, use a small pump and pressure gauge. Avoid using high pressure pumps made for cars and motorcycle tires, which can easily over-inflate and damage your ball.
Jul 18, 2012 | Sport & Outdoor - Others
Water inside basketball support
No, the automotive antifreeze is acidic, and will eat through the thin plastic.
A better option is RV Antifreeze - it is PINK and available at RV centers. You will need at LEAST 2 gallons to have the correct mixture.
Better option - empty it out, and fill with sand.
:D
Jan 15, 2009 | Lifetime 71729 In Ground Basketball Hoop
Replacment 7" basketballs
http://www.amazon.com/Voit-Voit%C2%AE-Super-Mini-Basketball-EA/dp/B001285TW8
One reviewer even specifically notes that he bought them for your same game.
Jan 04, 2009 | Park and Sun Sports PS-FAH Fold-A-Hoop...
Little Tikes DiscoverSounds Sports Center Colors/Styles Vary Logo
594 people viewed this question
Top Little Tikes Water Sport Experts
Marvin
Marvin
Bill Boyd
Tom Chichester
Are you a Little Tikes Water Sport Expert? Answer questions, earn points and help others
