The wireless drivers are probably not installed. you can get them from here
http://support.acer-euro.com/drivers/downloads.html
Ones the wireless drivers are installed along with all the other drivers and utilities you can get from acer, then you can turn on the wireless with the wireless button on your laptop, now you should have wireless connectivity.
Install and update the mother board installer..
SOURCE: i connot wifi connection on acer aspire 3610 in windows xp
1. check that the ipo address is set to automatic - not assigned
2. try pinging the router - you may be connected but the dns server may be an issue
SOURCE: Acer Aspire 3610 does not
If you are running windows vista or windows 7 then you need to go to the power setting on the system, in the advanced options and look for wireless power setting. Turn the when on battery setting to leave the wireless card running instead of turning it off.
Go to display settings, screen saver, power options, balanced power or power saver, and look in there for the wireless adapter.
Hi, Can you describe the problem in detail please.
