SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
SOURCE: service manual for xerox wc pro 416
This is the correct User Guide and System Admin manual even though it's for a 416Si.
System Admin: http://download.support.xerox.com/pub/docs/WCP_416Si/userdocs/any-os/en/wcp416_SAG_en.pdf
User Guide: http://download.support.xerox.com/pub/docs/WCP_416Si/userdocs/any-os/en/wcp416_UG_en.pdf
Hope it helps!
SOURCE: Error on wc 7120 xerox 124-315
hen look at these 3 locations and see if they match, If they do not set them to match the machine speed.
SOURCE: xerox WC 7132 printer error code 016-601 error and
cFor more help visit cbrtechsolutions
