Televison & Video Logo
seth Henderson Posted on Dec 11, 2015
I need to change the tv to HDMI
Comes on the screen that my tv is not formatted correctly. Sanyo says that I need to format it but I do not have a Phillips remote. I have direct tv. What do i do?
5 Related Answers
Anonymous
  • Posted on Jan 09, 2008
SOURCE: code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
A
Anonymous
  • Posted on May 05, 2008
SOURCE: Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Anonymous
  • 105 Answers
  • Posted on Jun 07, 2009
SOURCE: I need the codes for a sanyo tv to program my philips universal
please find the similiar type of the tv (must good tv) remove both tv memory ic and copy from the good tv.use memory ic copier all settle ok
Tony Walker
  • 393 Answers
  • Posted on Jun 21, 2009
SOURCE: need tv codes for phillips universal remote ph601s
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Puppet03
Puppet03
  • 172 Answers
  • Posted on Oct 24, 2009
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
My tv comes on shows a picture for a few seconds then it goes to a white screen no sound comes on. the screen says your tv does not support this programs content protection. replacing the tv HDMI cable...
Well either your HDMI source or the HDMI processing part of the TV is not right.
Try a different HDMI source and if the problem persists then it's the TV and you probably can't fix it on your own.
Or, of course, if you can use component cable just stay with it and save time and money.
2answers
Playing bluray through xbox one on toshiba TV
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
Tv says format not supported for my blu-ray disc player
Hmmm, interesting a tv with hdmi that does not recognise the format. Check the player on another tv first to make sure it is working correctly. If it is then check the hdmi settings on the tv in question to make sure that all settings for hdmi or the same as the tv it works on.
Just bought a Sanyo 32 in tv. When I play DVDs, it stretches the picture, which is already widescreen and 'letterboxes' it, leaving black strips top and bottom of the screen. Anyone know how to fix...
Usually to change the video format of your tv you will find it in the remote control try to look for format button in your remote there you can change the different aspect ratio of your video format settings. hope this help good day and best regards.
1helpful
2answers
How can i hook up a nintendo wii to my 50 inch sanyo plasma t.v and keep my digital cable hooked up at the same time?
I just took a look at the back of your TV and I know exactly what your problem is. First, you need to understand that digital cable is not HD cable necessarily and standard digital cable has analog outputs. Now, since you're concern is about not being able to keep your Wii connected to your TV without disconnecting your cable box, what you are telling me is that with the numerous numbers of input jacks on the back of your set (and the fact that the Wii comes standard with a red/white/yellow Analog Composite cable) you are using the only set of Analog Composite inputs (that also includes the S-Composite input) on your television set to connect your devices. Now, if you actually have an HD box, then you are not using the correct connections and cables and your beautiful 1080p Resolution High Definition television is displaying everything on cable at 480i Resolution, Standard Definition, even the HD channels. Analog connections are incapable of displaying in HD.
Now, I don't know about you, but when I put down my chunk of change and upgraded to HD, I wanted to make darn well sure that I didn't spend all that money to watch it in SD. Of course, that's tongue and cheek because I know you wanted the same thing and I'm going to walk you through the process of solving your problem and getting you the best picture possible out of your TV.
So the first order of business is to make sure that you have an HD box and if you don't you need to contact your cable provider and swap it out. Next you need to get yourself an HDMI cable for about $3. DO NOT waste your money on one in a store and do not believe any salesperson that tells you that the expensive ones are better than the cheap ones. They aren't and this is the biggest lie in consumer electronics perpetrated primarily by Monster Cable. Order it from Monoprice, as they are the best and cheapest. 6 feet is the standard.
http://www.monoprice.com/products/search.asp?keyword=hdmi+cable&x=0&y=0
An HDMI cable is one cable and all you need to do to connect it is put one end in the HDMI 1 input on the back of your TV and the other end into the cable box. It handles both the audio and video signals and your HD cable box should automatically detect it for video and audio. If by chance it doesn't detect the audio, go into the settings menu of the cable box and choose the audio sub-menu and set it to HDMI-out (these options might be under the heading "digital audio").
You'll also want to go into the video settings of your HD cable box and set the output resolution to only display one resolution (it will probably have several selected by default). Choose 720p or 1080i (your preference) as these are the only HD formats cable television broadcasts in. I have mine set to 1080i and the reason you do this is because not all channels are in the same resolution on digital and HD cable and what will happen is that your TV will have to reset its resolution every time you change channels and the resolutions change. This transition can take up to 30 seconds as you're sitting there staring at a black screen. By setting the resolution on your HD cable box to display only one of the HD resolutions, your HD box will simply upconvert the other resolutions automatically. I say choose between 1080i or 720p because not all cable providers broadcast in 1080i, using 720p exclusively so the 1080i setting is unnecessary.
Last thing about your display regarding HD cable: Your HD cable will display television programs in both the 4:3 (standard) and 16:9 (widescreen) formats. When the program is in 4:3, the image will not fill the entire display showing black bars on the left and right sides of the image. Plasma TV's are susceptible to what is called screen burn-in (or image retention or as Sanyo calls it, "after-image"). What this means is that if static images stay on the screen for too long, it will actually stay in the screen after you've changed the channel and it can be permanent and this damage is NOT covered by your manufacturer's warranty. Your TV has a feature to fix this (refer to your manual, near the end) if the "burn-in" is not too extreme, however the best way to avoid screen burn-in is to prevent from happening to begin with. While the TV is displaying a 4:3 program, the point where the image ends and the black bars (lack of image, technically) will burn-in. To avoid screen burn-in, you should change the format of the image to fill the screen via either your cable box (your cable remote will have either a Zoom key or a Picture Size key) or on the TV by pressing the PIX key on the lower left hand corner of your TV remote until you get the desired image. Use the option that zooms in, and not the option that stretches and distort the image. HDMI Cable captainhawk1_8.jpg
So now you have the Analog Composite inputs free to use for your Wii, however, I'm going to give you another alternative that will increase the quality of your picture when using your Wii. The Wii has the ability to use Component Video Cables for its video signal sent to your TV. Your TV has two Component Video Input Jacks (VIDEO 2 and VIDEO 3) and the are indicated by their red, blue, and green color. You'll still need to use the analog red and white audio connections when using the Component Video inputs but for this setup, they are right to the left of them.
Now, of course, Nintendo does make this cable but their's costs $20 and again, you can go right over to Monoprice when you get your HDMI cable and get it for less than $3 and like the Nintendo cable, it comes with the audio cables integrated. I have this cable myself and it makes an amazing difference.
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083007&p_id=5689&seq=1&format=2
Your TV will automatically detect both the HDMI connection and the Component Video connection so it will not require any setting up.
For more information refer to your manual, here:
http://us.sanyo.com/dynamic/product/Downloads/DP50747_Manual-31187309.pdf
Can I download a movie to a USB from a Sanyo LCD 40XR10F TV
No you can't download movies to the USB from a Sanyo LCD 40XR10F TV. You can view some movies stored on the USB, if in a correct video format to the Sanyo LCD 40XR10F TV using the built-in TV multi-media player. Due to updating of the TV, some formats may not play that once did.
2helpful
Hooking up pc through hdmi - red flickering image
The format from the PC needs to be an HDTV format: 480i, 480p, 720p, 1080i or 1080p. Other formats will generally not work. You may need to get the latest drivers from your video card manufactures website to correct the problem. I hope this was helpful, best wishes.
Philips DVD connected to SET TOP Box with W/R/Y cables. DVD connected to Philips TV via HDMI. Turn on DVD and TV screen says "Format Not Supported"? Help
Change the video resolution format from HDMI set up menu. This way you can know that if Player and TV supports/displays any one or some of the resolutions and if you can get a video on TV.
1helpful
Picture is cut off when watching hd stations on my sanyo 42 inch hdtv
You can't fix this problem using "pix shape" on the TV itself. To fix this common problem, just change the format on your SAT. BOX using your sat. remote; It should have a format button it. Just keep pushing the format button till you get the whole picture to show on screen and you should be set ...
Hooking Sanyo TV up to a computer
you need a hdtv tuner Hidef is different format than the rca jacks and digital won't worrk sorry.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
