How do you connect luxor 50inch smart tv to bluetooth. My ...
www.fixya.com/.../t26003543-connect_luxor_50inch_smart_tv_bluetoot...
4 hours ago - first turn on bluetooth and goto bluetooth settings and goto authentication and turnoff it.then bluetooth is connected ... when it asked for the pincode ...
40inch luxor tv - YouTube
? 0:29
https://www.youtube.com/watch?v=XrVJZtkV4sc
Aug 25, 2011 - Uploaded by jasonmctavish24
I bought this tv, now the picture is good for blu rays and my xbox etc. But it says 'DAVE' in really faint ...
SOURCE: Bluetooth Paired Up.
SOURCE: Bluetooth H500
when it asked for the pincode to paired the bluetooth headset enter the code 0000
SOURCE: what is the default code to pair a bluetooth with a lgcu920
The Default code for my Lg Vu is 0000 so i assume it shall be the same for yours.
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
SOURCE: pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
