Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
J
John Calhoun Posted on Dec 10, 2015
Grinder gets stuck with removal difficult for cleaning....fixable?
How do I clean the Black 3-oz. Coffee Grinder by Krups? Remnants of all the spices I used are stuck in the blade.
The best idea is to grind some rice to remove the spice pieces that are stuck. After doing this, wipe it clean with a paper towel or a cloth towel. Try not to get it wet, this makes all the spices get clumpy and it will be even harder to clean.
3answers
Saeco Incanto "grinder blocked"
provide in detail about your problem ..........
2helpful
Grinder blocked Saeco Caffe Charisma
If the problem is only just stuck then you should try to rutn the gringing adjustment to more gross grinding and first try to remove all remain coffee beans from grinder, with the use of avacuum cleaner try to clean everything from the grinder beans and grined coffee. Then try to make a coffee if it continue to be stuck turn for more gross coffee grinding clean with vacuum and try again is the grinder is only stuck then this will work if after all these the grinder does not turn then you will need to remove it and also you might need to replace it.
2answers
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Bench Grinder blown fuse
try the fuse first then try the red reset button under the base.
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Stuck
I had never heard this before, i will check this when i am on work again to see if i can give you a solution.
Best regards
/Mirran
2answers
Grinder hard (impossible) to remove
I had the same problem and used a little grease and it worked fine. Take out the bean cup and grease the male and female parts and it should work fine.
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
