Dell OptiPlex GX620 PC Desktop Logo
v
virginia smith Posted on Dec 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The computer won't let me in without a systm passwod it just started doing this
  • Official Brand Answer 560 Answers
  • Posted on Dec 10, 2015
DellCares
Level 0:
Answers
560
Questions
0
Helped
102073
Points
1292
Virginia smith,
Did you forget the password? Are there others that you share this computer with? System passwords are inputted in the computer by the users. Dell does not put any passwords in computers. Dell also does not have any generic passwords that will get you into the computer. You will need to find out the password, search the internet for password recovery websites, format and reinstall Windows or click the link below and view other ways that may be helpful in recovering the password.
http://bit.ly/1SQkaX7
Thank You,
Dell-Jesse L
1helpful
2001 cougar won't start
Cougar driving, then just stopped stalls rolling and will not restart? Tried everything? As seen all over the web, usually starts to missfire some first then suddenly dies never to start again? Changed every sensor with no luck? Even one person changed the entire engin and still didn't start.
Here's the deal, When cranking the engine notice that the RPM gage doesnt move, also if you checked, you are not getting spark or fuel, you probably had one ignition trouble code saying bank one or similar.
Long story short, it's the computer, PCM, engine management systm or whatever you want to call it. Yep thats it, that is the problem, a bad computer.
Open the hood, dissconect battery, now upper left, lift up the power steering resavoir, move it to the side. See the computer plug with the bolt in the center. Loosen the bolt all the way, go in the car under the passenger dash, remove screw holding the plastic tab under the computer, pull it down and out.
Now, get the info off of it, call a place online, I used AES, buy a remanufactered one, cost me about $300, once it arrives reinstall in reverse manner, connect the battery last. Now the cars security system will need programmed to the new computer so it will not crank yet, tow it to a local Ford dealer for about $60 , bring them all your keys and remotes, they will program the computer and security in about an hour for $115. Now your back in buisiness.
So plan to spend $475 bucks but that will do it.
3helpful
My 2004 Chevy suburban won't start but there is a locked padlock on dashboard , is this why?
sound like problem in the theft security systm,try this insert another key in the ignition switch, the other key could be worn where pcm and bcm dont recognize it. and switch ignition on engine off watch padlock symbol with ignition switch left on 10 minutes the padlock symbol will extinguish or turn off then you will turn off ignition switch wait 5 seconds then try starting vechicle if start your theft security failing need let dealership check it out.
How do i find my forgotten password or restore it without back up disc on the presariocq56
Use f10 setup, restore to default. which removes all passwords in the bios.
How to unlock an iPod and reset it?
The only way to do it is to re connect to a computer and reboot from backup or start fresh.
Whirlpool wtw5700sw0 sometimes won't spin
It is possible that the motor capacitor is weak and so does not start by itself. So use a similar value capacitor in parallel to confirm.check this link;
http://www.espares.co.uk/advice/washing-machines/a/7/1379/how-to-replace-the-carbon-brushes-on-a-washin.html
1helpful
For got password on my humax-hdr
Hello
The default password for this device is [ 0000 ]. Just enter this when it asks for password. Sometimes, it won't accept this at first time to cheat you. Just enter this once again. The set passoword will be cleared, and you have the chance to set an other password, and have to. OK.
Toshiba sattelite 1905-s301 master codes or passwod by-pass. forgot passwords to unlock computer for use and also forgot my bios password causing computer to keep running the start-up screan, safe-mode,...
I think if you do not have a recovery disc then the operating system needs to be reinstalled. It is also possible that the system needs a virus scan if there was a case of malwares within the PC.
2helpful
Jvm error 513 on my phone
When you use up all your tries it clears everything for security reasons. Do you have a sim card? If you take it out and type in the passwod for the last time, it wont do any damage. If you dont, Im afraid you are effed...
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
