Heating & Cooling Logo
A
Anonymous Posted on Dec 10, 2015
60000 BTU mitsubishi air.con is showing P8 error code and is blowing only hot air even temperature is set at 16 degrees. What might be the cause and how to rectify it.
Bill Boyd
Level 3:
Top Expert:
  • Mitsubishi Master 53,816 Answers
  • Posted on Dec 10, 2015
Bill Boyd
Mitsubishi Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949967
Points
172802
Go google and type in--Mitsubishi air conditioner fault code p 8-- and there are pages including a mitsubishi site that is a pdf version down load describing the fault
5 Related Answers
Anonymous
  • 20 Answers
  • Posted on Jan 11, 2009
SOURCE: Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Anonymous
  • 27 Answers
  • Posted on Nov 26, 2008
SOURCE: Mitsubishi Mr Slim air conditioner
get model and serial #s and look up unit for diagnostic codes
Don Berry
  • 230 Answers
  • Posted on Jun 18, 2008
SOURCE: Soleus MA-9000AH blows hot air
Sounds like the compressor is not running. This model had lots of problems with over heating. It also will never really blow more than a moderate cooling through it. Since you have cleaned all the filters and is still 100 deg, I believe the failure will be the compressor itself or the capacitor.
If you find an oily residue in the drain or on the pipes, it may have simply leaked the refrigerant out. Good Luck!
Anonymous
  • 400 Answers
  • Posted on Mar 09, 2009
SOURCE: mitsubishi heatpump not blowing out heat.
One reason could be a shortage of refrigerant. Another could be incorrect mode selection? Or the reverse valve which changes the unit from cooling to heating is either not being energised or may be blocked and would have to be replaced.
Anonymous
  • Posted on Jun 20, 2010
SOURCE: I have a Danby DPAC10030
Clean you filter and clean the area under the intake duck it will solve your problem
Error code c8
What causes the P8 error code? As we mentioned above, the P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
3helpful
2answers
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
3answers
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
1helpful
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Top Mitsubishi Heating & Cooling Experts
 Mikey
Mikey
vince
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
