I have a Technics PR-305 Digital Piano. I took it apart to clean the contacts under the keys That I attempted to do. Then later on I turned on My Technics PR-305 Digital Piano, and it didn`t work, Only the front light and LCD display worked. What would I do?
SOURCE: LCD Display screen on a Technics PR-305.
Only by replacing the screen.
Testimonial: "I`d like to thank you for the advice on liquid crystal display."
yes maybe you may fined that some of the power to the led is being blocked by causing a larger resistant to the led which will cause it not to light up as bright.
Yes. It is a fluorescent tube. It has to be from the OEM though.. It usually comes as a diver board and tube assy.
could be a power saving feature check your manual
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
This is something that I wanted to see if I could get the Technics PR-305 Digital Piano to work again, they are amazing pianos and easy to program, and are my favorite. I can make them sound like a five manual pipe organ too.
