SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: my vision fitness t9450hrt stopped mid run
Use your multi meter check continuity on motor leads if you get about 1 to 1.5 ohms if not leads may have open. You may also need to do calibration if the above check a ok.
SOURCE: Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
SOURCE: I have noticed a few times that my f3 life fitness
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
SOURCE: Problems: My Life Fitness
You must
calibrate the belt with a Allen wrench 5/16 inch turn in the direction
of clockwise at a speed of 1.5 to reach 4.5MPH you must turn the key
gently to prove that you slide about 10 seconds walk.Use WD40 oil on the joints to make it noise free.
http://www.treadmilldoctor.com/Troubleshooting
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
