Samsung BD-J5700/ZA - Streaming Wi-Fi Built-In Blu-ray Player Logo
M
Mary Barnett Posted on Dec 10, 2015
What cable do I need to connect this Blu-ray to my TV?
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
1helpful
How do I connect my Samsung BD-E5400 blu ray player to tv and watch netflix with a wired internet connection?
From the modem to the blu-ray use an ETHERNET cable. From the blu-ray to TV use an HDMI cable. They only fit in the right terminals.
3answers
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
2answers
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
I get picture but no sound on my samsung blu ray
  1. Are you connecting through HDMI?
  2. Do you have another source to test the HDMI cable to make sure it is not faulty?
  3. Do you have a second HDMI Cable you could test and connect with?
  4. Does your TV have another HDMI Connection you can use to connect with instead?
Essentially we are looking to determine whether or not it is the TV's HDMI connector, the Blu-Ray's, or just the HDMI cable in general.
1helpful
How do I change my tv to 1080p..its on 480I currently
You can't change the resolution on the television itself. You change the resolution on whatever you have connected to the television. Let's say it's a cable box or a blu ray player you've got connected to the television. First off you have to connect it to the television with a component (green, blue, red, white, red) cable or an hdmi cable. Then you make sure it is only connected to the television with either a component cable or an hdmi cable. This may sound ridiculous but there are some people that have their cable boxes and blu ray players connected to their televisions three different ways ( an hdmi cable, a composite cable, and a component cable) when they only need to have it connected one way.
Select the proper input on the television. Set the cable box or blu ray player's resolution to 1080i or 1080p (in the case of the blu ray player if it the tv will allow it).
1helpful
Pioneer elite 2006 50" tv How can I change from
2answers
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
