Electrical Supplies Logo
matt roth Posted on Dec 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 08, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5060338
Points
28436
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Jul 31, 2009
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Anonymous
  • 4088 Answers
  • Posted on Sep 26, 2009
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
rwvanlue
Roland W VanLue
  • 486 Answers
  • Posted on Dec 24, 2009
SOURCE: Recently a Generac 17kw natural gas generator was
There will be a normal odor as the engine cranks until enough gas is in the intake for starting. Gas generators do not have an ignition 'on-off' switch, they use a fuel solenoid to turn on and off the gas to start and kill the engine. If you are uneasy, your local gas company should be able to check engine compartment for leaks. Here in my home town, the gas company will inspect any equipment for gas leaks and/or carbon monoxide levels free of charge.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Testimonial: "Tks for the feedback on this problem, it is very informative. The faint gas odor persists when idle. Would this suggest a defective solenoid."
Anonymous
  • 2702 Answers
  • Posted on Aug 14, 2010
SOURCE: generator will not run. Can start generator by
you have a blocked up card jet strip carb and clean out all jets
check fule flow from tank as well also clean all filters air + fule
best advice on missing hurricanes,,is move away?
Sheldon Dedek
  • 912 Answers
  • Posted on Sep 15, 2010
SOURCE: I have a Coleman Powermate 4000 watt generator.
Hello Pete,
Is fuel actually leaking from the bottom of the bowl, or is leaking out the air filter and running down to the bowl?
If the former, then your bowl bolt's gasket has likely deteriorated. This would allow fuel to run down the bolt itself. Note that some carburetors will have a fuel shutoff solenoid (to the engine, not to the carburetor) that holds the bowl on, rather than a bolt. There will still be a gasket though. Turn fuel off before trying to service.
If fuel is running out from inside the carburetor (through air cleaner, etc), then you have a float / needle that is stuck. This is quite common after a small engine has been in storage and fuel was left in the carburetor. The residue causes the float to stick to the bottom. Turn the fuel off, undo the bolt that holds the bowl on, and carefully remove the carburetor bowl. Use a can of carburetor and choke cleaner to spray out the "gunk" in the bowl, spray off the float, and then reassemble. If it still leaks, then your needle seat will need to be replaced as well.
1helpful
2answers
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
2answers
Where to buy an air filter for tg3000 generator
Call 800 number or go online and look up repair parts dealers. These are Chinese generators and parts are hard to find. Also check with Tractor supply they can order parts for most of them.
4answers
Etq in1800i will not start
Did you just clean the Bowl in the Carburetor or did you make sure the tiny holes in the Jet was clean too? Not familiar with this model but I doubt it is anything more than Gravity fed.
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak...
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
2answers
UST GAS GENENTOR TG3000 WE DO NOT GET ELEC FROM THIS WE REPLACED FUSE AND STILL NOTHING SEEMS LIKE IT RUNNING GOOD WHAT CAN BE THE PROB
If it has been sitting for a while the electrical field may need to be flashed. Check falshing a generator and follow the directions. This should excite the generator and start generating again.
1helpful
Gas coming out of the air filter when generator is off and it wont stay running for long
Your float is likely sticking open, or more likey has a pinhole leak and is now full of fuel. The float isn't able to rise to level of fuel in the bowl and allow the needle to sit into the seat. The seat could also be damaged / have debris on it. First thing to do is remove the carburetor to check for debris and such in the bowl. Then check float, needle, and seat. Since you have the carburetor off anyways, put a rebuild kit in it.
2answers
I HAVE A ETQ 1200 GENERATOR I NEED ON THE
The pdf for this generator is available at easterntools.com
2helpful
3answers
Generator won't start
i have the same problem. i took out the air filter and sprayed tb into it and it ran and died. this is the only way to get it to fire up.
i took off the carb, dissasembled it and blasted it out with tb cleaner, took out the jets too, put it all back and it still does the same thing. it is getting fuel but it won't run.
need a profesional answer on this one please.
thanks, tom.
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
