Is the ac plug loose? If you wiggle it does the light come on and off? If that isn\'t the case and it powers up then goes right off sounds like an issue with your motherboard. If the unit is under warranty I would contact Lenovo. If the unit isn\'t under warranty you should try to blow it out with can air to get all the dust out of it to see if its a simple over heating issue. If the unit still doesn\'t post, sounds like you have a bad motherboard. Let me know if you have any other questions. Good place to find more info:
http://support.lenovo.com/en_US/Just need to type in your model number which can be found on the bottom of the laptop. should be MTM:XXXX-XXX
