COF 32 ATDC sensor failure.Enter in the service mode select Then.rep.mode select printer mode select ATDC gain adjustment note the current value then clear the current value and change the value up or down.Ex: the current value = 150 clear and change to 154 ,make a few copy and if the error code not displayed is OK.If the error code is appaire clear the value and enter 132,make a feww copy,if OK you are resolved a problem. Service mode entering: press utility key-press metercount-press details(if apaire the details windows)-press Stop 0 0 Stop 0 1 (if appaure admin code press 00000000 ) select techn.rep.mode-printer etc.
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE SEQUENCE (cont.) You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting. Push the start/pause button.To cancel the test mode, press on "power". You will be able to choose another test mode and again press on "start/pause". The display error codes test allows the service technician to examine and clear the fault log. DISPLAY ERROR CODES TEST (t02) The display error codes test allows the service technician to examine and clear the fault log. The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display. The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log. After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display. The control shall log the last 8 error codes in the non-volatile memory stored in a circular list. The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
This problem seems to be associated with Boot loading files.
Try this:
1. Boot the Windows XP CD-ROM.
2. Choose the Install option.
3. Next screen, there will be option to select Repair your Windows Installation.
4. Once repair is over, you shall be able to boot your system.
Thanks
Thiyaga
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds. 2.Reconnect the power and within 30 seconds press the sequence of buttons listed below. 3.Press the "SIGNAL"button. 4.Press the "DELAY START"button. 5.Press the "SIGNAL"button. 6.Press the "DELAY START"button.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
maybe processor crystal is located on mainboard is falling, and the message" CLOCK_WATCHDOG_TIMEOUT" is the processor checkup status flag, for stucked data, maybe a defective processor or a defective motherboard, send to repair.
