Question about Creative Labs Computers & Internet
My creative 5:1 PC speaker system not working ,as the main circuit in the woofer box hs gone defective. Can I get the main circuit board in spare? .Pl. help.
Need to change the main PC board in the woofer box. Is a spare circuit board available/
SOURCE:
SOURCE: WOOFER NOT WORKING JVC th-m606
I'm having the same problem. It seems that the mosfet's shorted blew up a capacitor and took some surface mount parts with it. It will be the middle board with the metal shroud (shield). The mosfets are almost impossible to find, I have replaced them (as well as other parts) but still have yet to find the problem. I'm now trying to find the subwoofer amp board (part#LVA10505).
Posted on Feb 23, 2008
chinmay_lp
  • 271 Answers
SOURCE: speaker sound is very low
Open the master volume control window by clicking the sound icon on the right hand side of your taskbar(near your clock).and check the balance is set to low for your speaker or not.try to set it at centre.
or try to update your sound driver.
Posted on Mar 10, 2009
SOURCE: creative 5 in 1 speaker set up
buy jack to connect all the cables.
because computer are only two output audio terminal.
Posted on Apr 27, 2009
  • 202 Answers
SOURCE: problem with creative 5.1
you should not have a problem running the card, check these:
1 is the sound muted? control panel sound and audio dev.
2. is the card properly seated in the slot?
3. are the speakers working and plugged in the right port
4 control panel, system, hardware ,dev mgr look in the list for sound,video and game controllers see if you have a problem there, unknown device memory conflict or other.
5 does the mother board have built in sound? if so you will have to disable it in bios before you can use another card.
hope this helps and good luck
Posted on Jul 23, 2009
ViscamTech
  • 528 Answers
SOURCE: At a time only two speaker works out of 4
1. Open Control Panel > Sounds and Audio Devices. 2. Click 'Advanced' Button near the bottom. 9d7466a.jpg
3. Select proper sound system (Quadrophonic or surround sound) according to your speaker system.fc6ac4d.jpg 4. Click 'OK'. 5. Also check volume. 6. Double-click Volume icon in taskbar. 7. Click Options > Properties (From menu) and select 'Playback'. 8. Select all Audio components. 9. Click 'OK' 10. Increase all the volumes.
Now try playing a sound. Good Luck!
Posted on Jul 30, 2009
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
mosfet's might have shorted and blew up a capacitor and might have took some surface mount parts with it.it will be in the middle board with the metal shroud (shield). try to replace it .
Aug 12, 2008 | JVC TH-M606 System
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
Power was given to the Woofer and main board of MX5021 without connecting satellite speakers. There was a sound (may be some device burnt out) and the system became non -functional. The service...
Ideally since this a audio amplifier you can replace with the types that are in the market which can be done up by a competent service engineer.
You can choose the power output based on the wattage of the woofer as some of these companies do not have good support base and spares will be hard to find for a full board replacement. So if your speakers are in order then you can have this choice-- get opinion before you invest or else buy one home theatre amplifier off the shelf that suits the speakers.
Aug 24, 2011 | Altec Lansing MX5021 System
Hi, I own a HTSS3455 Home Theatre system since 3 years and it worked without any complaints since then but since last month I am facing sub woofer issues ..when I increase the woofer base volume above 5...
Hi, kumar,
I am also using the same model but i got problem in DVD player but my speakers are working fine. I am from Pakistan and here i didn't find the spare part of MPEG main board card. If you wanna buy my Speakers or if you wanna sell ur DVD player contact me on sajjadzaidi@hotmail.com.
Aug 25, 2010 | Philips HTS3450 System
I have creative 2.1 channel with sub woofer and 2 speakers (left&right) all of sudden my right speaker is not working left only working then I pluggeg right speaker to left speaker jack in sub...
I have a similar reoccuring problem with the left channel on my speakers. All of a sudden, while playing music or whatever, the left channel jusr dies. Turning the system off and then on again from the conrol unit does not remedy the situation. By chance, I discovered a workaround to get the left channel working again: Push the main power switch of the subwoofer until it almost switches off and then release it so that the power is never actually switched off. Now a click is heard in the system and the left channel comes alive again. This is quite annoying and seems to have something to do with switches in the subwoofer. Low quality components may have been used. I 've been thinking of getting another 2.1 system, but it's not easy to find one... Maybe I should open the subwoofer box and go through the switches and possibly hardwire some connections...
Jun 27, 2010 | Creative Labs MegaWorks THX 250D Computer...
My creative speakers woofer is damege plz repair woofer.
sir I am using 2.1 creative inspire speakers system, at present no sound is coming in the speakers or woofer, what is the problem.
power is on and after connecting the speakers to woofer from pc no sound is coming. what is the problem. please help me. thanks rajanna
Jun 01, 2010 | Creative Labs Inspire 6600 Computer...
I installed Win XP Sp3, I have creative 5.1 speakers, But 1 speakers is not working?
Check the Woofer's cable that is attached with the speakers and woofer and also woofer. and system !!!!!!!!!!!!
Apr 24, 2010 | E-Machines eMachines Desktop PC
Surround sound
please confirm the  cables between speakers and main unit-no open circuit or broken jack or connector-repeat your speaker setup and confirm that rear and woofer are in on status,
Jul 27, 2008 | Audio Players & Recorders
Computers & Internet Logo
201 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
Damen Wong
Damen Wong
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
