Motorola Mobility Black Motorokr S305 Wireless Stereo Headphones In Retail Logo
George Riegel Posted on Dec 07, 2015
Why is headphone volume low and can't be increased?
Doesn't work, I've tried the volume buttons. I've tied to reset, doesn't work either?
The volume is very low
If the volume is very low on your phone, try increasing the volume button on your phone. if this still doesn\'t work this may mean that you have an issue with your built in speaker. bring your mobile device to your Mobile shop dealer where they can investigate the problem.
I ave to put iphone on speaker to talk to people cos they CANT HEAR ME wats wrong with my iphone
Try increasing the volume both with the hardware buttons and through the software in Settings. If not try to reset it by pressing the power and home buttons at the same time until the Apple logo appears. If his doesn't work, either restore it through iTunes or take it to an Apple Store to check for hardware problems.
13helpful
2answers
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
My Dell Latitude E5500 speaker is too low, how to increase volume?
If you have volume control in the system tray (bottom right corner), double-click it. In Windows XP you will see all the sound controls. Increase all to the maximum level (except microphone).
Use the buttons close to the screen to increase the volume.
There is a volume control in the player you are using. Increase it to the maximum.
If it doesn't help, please let us know.
1helpful
I have a 42PC5 LG Plasma, and the problem is that the TV Remote control and Buttons (on the TV) are not working/responding. The only way to close the TV is by plugging out the Electricity Cable, and when...
i think that there is a shorted buttons or in normally close position, try to press each buttons slowly and you will feel something that is ticking if one of the buttons does not tick it is damage it is in normally close position that will be the cause of the problem. specially check the volume button.
2answers
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
How do i increase the volume. Even on high it doesn.t have enough volume for our hard to hear parents
I would suggest a couple sets of wireless headphones for older folks. That way the sound is right at their ears. Otherwise you can try hooking up the audio out line of the set to the auxilliary port of a stereo. Good luck.
Motorola S9
I heard that volume work with nokia and moto sets only ... which set are u using?
My psp sound quit working. it went low and now no sound at all.
I take it the volume control doesn’t change it? If the level went down rather fast the Volume decrease button (-) might have gotten stuck down.
Have you tried different set of ear buds (headphones)?
Top Motorola Mobility Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
john h
August Brown
August Brown
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
