Calculator works in non-print mode but prints gibberish when attempting to print on tape. Is there a keying sequence that resets it to normal printing?
Short answer is no. These are low end calculaotors and parts are hard to obtain. These calculators are cheap and basically disposable. It is cost prohibitive to replace the printer in them.
Sorry.
SOURCE: printing problem
Try resetting the calculator. There should be a reset button on the underside of the machine. Press it with a pen and that should clear the E that is on your display.
SOURCE: Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
SOURCE: how to reset tax % on casio HR-100tm
the 0 disappeared and reappears. Then type in your tax rate and the
percent key (Eg: 8.25%) and then press the TAX+ key. It should save the
new tax rate.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: loading paper tape
Well, I just had a long and vigerous fight withmy new HR-8TM. I came here and read all the before mentioned solutions. Then the idear struck me. Instead of cutting the paper even all the way across the roll, I cut it slanted on the sides and straight across the middle " __ " and guess what it passed the roller feed through.
It worked for me, maybe it will work for you.
SOURCE: Casio HR-150TER calculator fault -E appears on
Casio HR-150TER calculator fault -E appears on screen & will not print. Thank you
