THE SENSOR IS BAD ,TAKE IT BACK TO STORE AND ASK FOR ANOTHER ONE,IF BOUGHT AT WAL-MART AND THEY GIVE U PROBLEM TELL THEM U R GOIN TO CALL 1 800 WAL MART THEN DO IT WHILE IN STORE THEY WILL MAKE THEM EXCHANGE IT
Answer I had the same problem and here is the answer I found
at leapfrog.com which fixed my daughter’s disney princess leapster 2’s
problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to
hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
problem. Good luck!
5) Restart unit
1) Ensure that a cartridge is not inserted2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.3) When the LEAPSTER menu screen appears, press the A button4) Touch each of the crosshairs that appear with the stylus5) Restart unit
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
