I have a mtx 311d and some of the transistors beneath the heat sink are burnt beyond recognition. Can anyone help?
SOURCE: No HT, components burnt
You can check out this website for your service information and parts: https://spares.bigwarehouse.com.au/index.php?cPath=24759_24762_24803 Paste the address in to your address bar. That will take you to the website. They had three of the four parts that you needed listed on the website 1.Q706 -Transistor bipolar FJAF5804 (TU) Fairchild $ 49.61 2. C744-Capacitor drawing SM SHR SYE/SWE 160V $ 19.06 3 R809- Resistor fixed small 1 ohm 2W 5% SF. $ 14.27 They also sold the service manual for $ 29.57. I hope this helps you with your problem.
SOURCE: Amp and sub have been working great together then
check to see if one of the RCA cables is unplugged or bad. check the gain check the sub level control on the deck if yours has one.
SOURCE: a transistor or resistor burnt
You have not mentioned what electronic equipment you are requesting the details.
You will be able to confirm the transistor value from the stage where it has burned which also goes for the resistor. So take tech help than to try with trials to damage the set much further.
SOURCE: WANT A CIRCUIT DIAGRAM BP600.1 OR THE NAMES OF
if i can get a diagram for jbl bp600.1amp pls and ty
SOURCE: need circuit diagram
We have your question and someone will answer in due course. Stop posting.
