SOURCE: Cassette will not load!
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100.
SOURCE: No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
SOURCE: Sony Mini camcorder DCR-HC21 problem with LCD and viewfinder. need help ASAP!!
i have the same problem,i opened the camera, i have taken out the flexible cable, its broken at the hinge...it looks like a bad design of the cable is the reason.
the cable is 1cm in width and at one point when it passes through the
hinge the cable is split into two with .5cm width each. one cable is cut at the pt where it enters the hinge, this cable is stretched to fit into the hinge, guess thats why it broke so soon...
It would be great if some1 can guide on from where and how to get this cable..
Anand
SOURCE: Problem w/ JVC Digital Camcorder GR-D33US
Found this on the JVC Website, gonna give it a try and see what happens...
CCD Program for This Model - GR-D33US
JVC has received reports that in certain circumstances, this model may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at JVC Factory Service Centers. Click this Repair Request link to download a Repair Request Form and find your nearest location.
Please call our Customer Care Center at (800) 858-6442 if you encounter any problems in obtaining a free repair. We apologize for any inconvenience and are appreciative of your understanding and support.
JVC reserves the right to terminate this program at any time with appropriate notice on this web site.
SOURCE: black screen on camcorder
I think you have two different issues here. The black screen may be due to a CCD failure. Canon has a worldwide service notice regarding this issue, and will repair your unit at no cost if they determine this is the problem (it sounds like it is).
The little red symbol indicates your backup battery (or date/time battery) CR1616 needs to be replaced. It is located behind a small square panel which you can see to the left of the menu buttons when you open the LCD panel.
