Watches Logo
A
Adam Kalish Posted on Dec 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What kind of watch winder do I need for this watch
I want to purchase a watch winder so when im not using it it will constantly move. what direction will this watch need to move as there are many different watch winders and I want to ensure i get the right one..thanks
  • 1 more comment
  • Adam Kalish
    Adam Kalish Dec 06, 2015
    I clicked stop wanting answer by mistake
  • Adam Kalish
    can anyone let me know what movement this watch needs to I can order the right watch winder as I dont want to pay 500 for an overhall
    thanks
  • Adam Kalish
    style CJF2110.BAO576
June Elliot
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 14, 2019
June Elliot
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
347
Points
5
My husband has he same watch and he got a Wolf 456002 from Amazon a year ago. He is very happy with it. This guide helped him a lot when he was looking for one:
thewatchsnob.net/best-watch-winder
deton8 von Splosion
Level 3:
  • Tag Heuer Master 3,342 Answers
  • Posted on Dec 06, 2015
deton8 von Splosion
Tag Heuer Master
Level 3:
Answers
3342
Questions
6
Helped
928823
Points
54123
You have selected a wonderful watch... Heuer and TAG/Heuer should be gently wound by the motion of the human wrist and the falling of a centrally pivoting weight (there is no ideal direction).
AUTO-WIND function is NOT at all unique to your watch...
After a couple of CHEAPER "winders" failed me... and after I figured about 4 watches was more than enough to keep wound... I found the greatest BASIC watch winder... to run year over year (efficiently and quietly)
MTE watch winder (their very basic WTS-4).
Good luck: I WILL try to include the URL (see page 6)
http://mte-watchwinder.com/fileadmin/PDF-Uhrenbeweger/MTE_Watch_Winder_Brochure_Engl.__09-2015.pdf
Hi there, I just received a Kubrik Startbox for Christmas. Problem is my Breitling Superavenger seems too heavy for the winder. It starts to rotate then stops Please advise
Hello Damon Hiley
Beautiful Winder... (BUT RELAX)
It does not NEED to move constantly...
only enough the change position to allow the
self wind weight. to move a little... GENTLY.
Just like the normal movement of a PILOT...
HOLDING the controls steady...
(NOT cheerleaders)
Working as it should.
Carnac the Magnificent
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
How do I activate the watch right after purchase?
there should be a plastic tab behind the winder pull it out and push the winder in then it will start running
Feb 19, 2014 • Watches
Why does the time stop after six to eight hours? Do I have to wind it often?
I'm guessing it's a Fully Automatic watch,which if worn all day should store enough 'kenetic energy'without manual winding!! You can buy watch winders on eBay that constantly move the watch when your not wearing it to keep it wound up!!
Dec 08, 2012 • Watches
How long do Buluva keep spare parts, looking at purchasing a watch, but want to be able to get spare parts if need be
Depends on what kind of parts you are talking about. Depending on the popularity of the style, styles can change constantly. I would contact Bulova direct at the following link:
http://www.bulova.com/contact/contact.aspx
1helpful
I have just purchased a guess w12575 ladies watch but am unable to alter the time on it as the winder won't open. i had no instructions in the box when it arrived to help me. I have tried pulling the...
Some winders need to be unscrewed (its a water resistance feature).
Try turning the winder anticlockwise about a quarter of a turn or so.
(Don't forget to screw it back in when you have finished!)
How do I start my Pulsar watch? The instructions said to swing it side to side for 30 seconds...that didn't work. Checked the battery and it's ok..even exchanged the watch but this one's the same...I...
If you're supposed to swing it, that means it's an automatic or kinetic watch and it charges it's battery using an internal winder that moves as the watch moves. Try wearing it for a while, being mindful of moving your hand, or if that doesn't work try using a watch winder. If none of that works it probably needs a new movement. Take it to your dealer to submit for warranty.
Dec 20, 2009 • Watches
I need to know if I need to purchase a watch winder for my TAGs
Use a winder if you must but I recommend just winding and setting when you want to wear them as most winders I have seen are very cheap and unreliable. Expect up to 50 hours from most watches usually not less than 30, this is if the have recent< 5 years, overhaul.
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
