Zebra Z6M Plus Thermal Label Printer Logo
A
Ali AB Sagier Posted on Dec 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing blank label
Zebra printer prints label without any data , already i print out the test label it is ok .
kbtkbt
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 67 Answers
  • Posted on Feb 10, 2016
kbtkbt
Expert
Level 2:
Cheetah:
Answers
67
Questions
0
Helped
32620
Points
104
You need to give more info.
Are you using labelling software?
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Apr 24, 2008
SOURCE: Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Thomas7
  • Posted on May 05, 2008
SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
WillBGood
  • Posted on Jun 10, 2008
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Anonymous
  • 10 Answers
  • Posted on Feb 17, 2009
SOURCE: Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Anonymous
  • Posted on Mar 11, 2009
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Prints label then prints a blank
This is always a calibration or label template size issue.
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Label double print
It's possible that the printer did not get a good calibration on the size of the label. There's an optic sensor looking for the gaps in the labels. A test would be to turn the printer off and back on again. When it is ready, just press the feed key. If one label advances then the printer had a good read on the label size. The idea is to see if the printer works ok by itself first.
Now print a label - if you get two labels then you have to look at the software / printer driver as the cause. The printer will only do what it's told to do.
Hope that helps !
1helpful
New z4m is printing the data too big for the label and is skipping labels. Prints one, then a blank. I have several Zebra printers and the set up seems to be simular however I cannot get this one to print...
have you installed all the drivers correctly
and are you printing using the software that came with the printer or are you using word
if you are using word change the diamentions of the sheet when you go to print
Labels are blank
Check first ribbon and the label are OK. After check the darkness settings are correct. And finally prints a test print.
Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
2answers
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
