Supersonic SC-23G DVD Player Logo
Mary Spangler Posted on Dec 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I check the NTSC/PAL setting? - Supersonic SC-23G DVD Player
Marvin
Level 3:
Top Expert:
  • Supersonic Master 85,242 Answers
  • Posted on Dec 31, 2016
Marvin
Supersonic Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056948
Points
266281
If it was sold in the US or Canada then it is NTSC, but if you changed it, go into the players menu options, it is there.
How do I make it play in color?
what color system is tv and what color system is dvd set to.
PAL to PAL
NTSC to NTSC
NTSC to PAL = no color
PAL to NTSC = no color
My tv has gone black and white I dont know how to get the colour back
check color system matches . If tv uses PAL then DVD player needs to be set to PAL. If TV station uses PAL then set devices to PAL. If TV station uses NTSC set devices to NTSC for color system.
This sony ccd fx620 plays tapes but they only show in black and white on the TV. Should this unit show in color and if so can it be fixed?
check compatibility between camera and tv. is the camera ntsc or pal system? is the tv ntsc or pal system?.
the tv and the camera need to be set at the same system, both on ntsc or both on pal. pal system is used on europe and ntsc in america and japan-.
Why does it only play dvds in black and white
check color system settings pal to pal
TV PAL then DVD player has to be PAL
TV NTSC then DVD player needs to be NTSC
If mismatch in settings you may experience black and white
Change ntsc to pal
The manual seems to indicate that the TV will automatically detect what signal type is present, so PAL should be recognized. There is, however the possibility that the "Color System" setting under the system menu may not be set to "AUTO", but NTSC. This would cause a conflict when detecting PAL input and affect picture. Check the "Color System" and either select PAL or AUTO and see if that helps.
No sound on playing games but have sound on movies
You need to check your audio settings
1) ensure they are correct
2) ensure games are ntsc if your region is ntsc and not pal because video might revert and not audio.
3) If wma is enabled make sure you are using ntsc again and also
4) If the ps3 is using jailbreak game could be corrupt
but i would guess it could be 2 so check your tv settings properly because pal games work when ps3 is in pal mode and ntsc when ps3 is in ntsc mode with sound.
I bought an HDTV LCD Sanyo from USA got it with me to Lebanon, when I turn the TV on the picture is so clear but it will not work on the satelite or caple, the picture not clear and has no voice. I need to...
There are currently 3 main television standards used throughout the world:
NTSC - National Television Standards Committee. The oldest existing standard, developed in the USA. First used in 1954. Consists of 525 horizontal lines of display and 60 vertical lines. Sometimes irreverently referred to as "Never Twice the Same Color." Only one type exists, known as NTSC M.
Here is a list of TV STANDAREDS I had for a while and can finally share it with someone. GOOD LUCK!!!! TECHMAN
SECAM - Système électronique pour Couleur avec Mémoire. Developed in France. First used in 1967. A 625-line vertical, 50-line horizontal display. Sometimes referred to by wags as "Something Essentially Contrary to the American Method" or SEcond Colour Always Magenta!" Different types use different video bandwidth and audio carrier specs. Types B and D usually used for VHF; types G, H, and K for UHF; types I, N, M, K1 and L for both VHF/UHF. Different types are generally not compatible.
PAL - Phase Alternating Line. Developed by German engineer Walter Bruch and the German electronic corporation Telefunken. Walter Bruch
patented his invention 1963 and the first commercial application of the PAL system was in August 1967. Also a 625/50-line display and variant of NTSC. Proponents call it "Perfection At Last." Due to the cost of the enormous circuit complexity, critics often refer to it as "Pay A Lot". Different types use different video bandwidth and audio carrier specs. Common types are B, G and H; less common types include D, I, K, N and M. The different types are generally not compatible.
Television Standards by Country
COUNTRY SIGNAL TYPE
AFGHANISTAN PAL B, SECAM B
ALBANIA
PAL B/G
ALGERIA
PAL B/G
ANGOLA PAL I
ANTARCTICA NTSC M
ANTIGUA & BARBUDA
NTSC M
ARGENTINA
PAL N
ARMENIA SECAM D/K
ARUBA
NTSC M
AUSTRALIA
PAL B/G
AUSTRIA
PAL B/G
AZERBAIJAN SECAM D/K
AZORES PAL B
BAHAMAS
NTSC M
BAHRAIN
PAL B/G
BANGLADESH
PAL B
BARBADOS
NTSC M
BELARUS SECAM D/K
BELGIUM
PAL B/H
BELGIUM (ARMED FORCES NETWORK) NTSC M
BELIZE
NTSC M
BENIN SECAM K
BERMUDA
NTSC M
BOLIVIA
NTSC M
BOSNIA/HERZEGOVINA
PAL B/H
BOTSWANA SECAM K, PAL I
BRAZIL
PAL M
BRITISH INDIAN OCEAN TERRITORY
(AF DIEGO GARCIA TV - AFRTS) NTSC M
BRUNEI DARUSSALAM
PAL B
BULGARIA
PAL
BURKINA FASO SECAM K
BURUNDI SECAM K
CAMBODIA
PAL B/G, NTSC M
CAMEROON PAL B/G
CANADA
NTSC M
CANARY ISLANDS
PAL B/G
CENTRAL AFRICAN REPUBLIC SECAM K
CHAD SECAM D
CHILE
NTSC M
CHINA (PEOPLE'S REPUBLIC)
PAL D
COLOMBIA
NTSC M
CONGO (PEOPLE'S REPUBLIC) SECAM K
CONGO, DEM. REP. (ZAIRE)
SECAM K
COOK ISLANDS PAL B
COSTA RICA
NTSC M
COTE D'IVOIRE (IVORY COAST) SECAM K/D
CROATIA
PAL B/H
CUBA
NTSC M
CYPRUS
PAL B/G
CZECH REPUBLIC
PAL B/G (cable), PAL D/K (broadcast)
DENMARK
PAL B/G
DIEGO GARCIA NTSC M
DJIBOUTI SECAM K
DOMINICA
NTSC M
DOMINICAN REPUBLIC
NTSC M
EAST TIMOR
PAL B
EASTER ISLAND PAL B
ECUADOR
NTSC M
EGYPT
PAL B/G, SECAM B/G
EL SALVADOR
NTSC M
EQUITORIAL GUINEA SECAM B
ESTONIA PAL B/G
ETHIOPIA PAL B
FALKLAND ISLANDS (LAS MALVINAS) PAL I
FIJI NTSC M
FINLAND
PAL B/G
FRANCE
SECAM L
FRANCE (FRENCH FORCES TV) SECAM G
GABON SECAM K
GALAPAGOS ISLANDS NTSC M
GAMBIA PAL B
GEORGIA SECAM D/K
GERMANY
PAL B/G
GERMANY (ARMED FORCES TV GERMANY) NTSC M
GHANA
PAL B/G
GIBRALTAR
PAL B/G
GREECE
PAL B/G
GREENLAND
PAL B
GRENADA
NTSC M
GUAM
NTSC M
GUADELOUPE SECAM K
GUATEMALA
NTSC M
GUIANA (FRENCH) SECAM K
GUINEA PAL K
GUYANA NTSC M
HAITI
SECAM
HONDURAS
NTSC M
HONG KONG
PAL I
HUNGARY
PAL K/K
ICELAND
PAL B/G
INDIA
PAL B
INDONESIA
PAL B
IRAN
PAL B/G
IRAQ
PAL
IRELAND, REPUBLIC OF
PAL I
ISLE OF MAN
PAL
ISRAEL
PAL B/G
ITALY
PAL B/G
JAMAICA
NTSC M
JAPAN
NTSC M
JOHNSTONE ISLAND NTSC M
JORDAN
PAL B/G
KAZAKHSTAN SECAM D/K
KENYA
PAL B/G
KOREA (NORTH)
SECAM D, PAL D/K
KOREA (SOUTH)
NTSC M
KUWAIT
PAL B/G
KYRGYZ REPUBLIC SECAM D/K
LAOS PAL B
LATVIA PAL B/G, SECAM D/K
LEBANON
PAL B/G
LESOTHO PAL K
LIBERIA
PAL B/H
LIBYA
PAL B/G
LIECHTENSTEIN
PAL B/G
LITHUANIA PAL B/G, SECAM D/K
LUXEMBOURG
PAL B/G, SECAM L
MACAU PAL I
MACEDONIA PAL B/H
MADAGASCAR SECAM K
MADEIRA PAL B
MALAYSIA
PAL B
MALDIVES PAL B
MALI SECAM K
MALTA
PAL B
MARSHALL ISLANDS NTSC M
MARTINIQUE
SECAM K
MAURITANIA SECAM B
MAURITIUS
SECAM B
MAYOTTE SECAM K
MEXICO
NTSC M
MICRONESIA
NTSC M
MIDWAY ISLAND NTSC M
MOLDOVA (MOLDAVIA) SECAM D/K
MONACO
SECAM L, PAL G
MONGOLIA SECAM D
MONTSERRAT NTSC M
MOROCCO
SECAM B
MOZAMBIQUE PAL B
MYANMAR (BURMA)
NTSC M
NAMIBIA PAL I
NEPAL B
NETHERLANDS
PAL B/G
NETHERLANDS (ARMED FORCES NETWORK) NTSC M
NETHERLANDS ANTILLES NTSC M
NEW CALEDONIA SECAM K
NEW ZEALAND
PAL B/G
NICARAGUA
NTSC M
NIGER SECAM K
NIGERIA
PAL B/G
NORFOLK ISLAND PAL B
NORTH MARIANA ISLANDS NTSC M
NORWAY
PAL B/G
OMAN
PAL B/G
PAKISTAN
PAL B
PALAU NTSC M
PANAMA
NTSC M
PAPUA NEW GUINEA PAL B/G
PARAGUAY PAL N
PERU
NTSC M
PHILIPPINES
NTSC M
POLAND
PAL D/K
POLYNESIA (FRENCH) SECAM K
PORTUGAL
PAL B/G
PUERTO RICO
NTSC M
QATAR
PAL B
REUNION SECAM K
ROMANIA
PAL D/G
RUSSIA
SECAM D/K
ST. KITTS & NEVIS
NTSC M
ST. LUCIA
NTSC M
ST. PIERRE ET MIQUELON SECAM K
ST. VINCENT
NTSC M
SAO TOMé E PRINCIPE PAL B/G
SAMOA, AMERICAN
NTSC
SAUDI ARABIA
SECAM B/G, PAL B
SAMOA NTSC M
SENEGAL
SECAM K
SEYCHELLES PAL B/G
SIERRA LEONE
PAL B/G
SINGAPORE
PAL B/G
SLOVAKIA PAL B/G
SLOVENIA PAL B/H
SOMALIA PAL B/G
SOUTH AFRICA
PAL I
SPAIN
PAL B/G
SRI LANKA PAL
SUDAN
PAL B
SURINAME
NTSC M
SWAZILAND PAL B/G
SWEDEN
PAL B/G
SWITZERLAND
PAL B/G
SYRIA SECAM B, PAL G
TAHITI
SECAM
TAIWAN
NTSC
TAJIKISTAN SECAM D/K
TANZANIA
PAL B
THAILAND
PAL B/M
TOGO
SECAM K
TRINIDAD & TOBAGO
NTSC M
TUNISIA
SECAM B/G
TURKEY
PAL B
TURKMENISTAN SECAM D/K
TURKS & CAICOS ISLANDS NTSC M
UGANDA
PAL B/G
UKRAINE
SECAM D/K
URUGUAY PAL N
UNITED ARAB EMIRATES
PAL B/G
UNITED STATES
NTSC M
UNITED KINGDOM
PAL I
UZBEKISTAN SECAM D/K
VENEZUELA
NTSC M
VIETNAM
NTSC M,SECAM D
VIRGIN ISLANDS (US & BRITISH)
NTSC M
WALLIS & FUTUNA SECAM K
YEMEN
PAL B/NTSC M
YUGOSLAVIA PAL B/G
ZAMBIA
PAL B/G
ZIMBABWE
PAL B/G
2answers
Rf signal pal to ntsc
there should be an option in your picture settings menu
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Please help
Have you try: NTSC on PAL TV On • NTSC discs will play correctly on PAL-only TVs.
Off Use if your TV is already NTSC-compatible.
Many recent PAL TVs are compatible with NTSC input and so this setting can be switched off. Check the operating
instructions that came with your TV. See also About NTSC on PAL TV on page 124 for related information.
Top Supersonic Televison & Video Experts
NOEL
NOEL
Ngoro
SmartAviator
SmartAviator
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
