reggie maness Posted on Dec 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My eclipse fit clip shows music in the folder but wont play any
When the music file is selected it says empty however it says there is music stored on the folder how do i get it to play
Will Mishler
Level 2:
Sergeant:
  • Expert 307 Answers
  • Posted on Jan 25, 2016
Will Mishler
Expert
Level 2:
Sergeant:
Answers
307
Questions
0
Helped
75183
Points
741
Seems like the names were copied but not the music files try syncing with Windows Media player form a playlist
Is it possible to change the order of the tracks?
When listening to music, you can hit 'M' to access the menu. Whilst in the menu, go down to Repeat. The sub-folder has several different options, among them being Random All on the second page. Though the order it plays songs in does not often differ (i.e. When you click random, it will always play Track 4, then 9, then 2, and so on and will do this again the next time you go into your music selection), it can be useful for when you have prior sub-folders to trade off between.
If you have already tried this, you can also plug your player into your desktop computer and move the songs off of the player via the folders available there. When you re-upload files, they tend to be in alphabetical order, so you can also rename them (i.e. from "Charlie on the M.T.A." to "01 Charlie on the M.T.A." and so on and so forth) to get them in a playlist-style format. If you have more than thirty files in a folder on the device, things tend to become out-of-sequence anyway, so that can add a pleasingly random element to your music.
Enjoy <3
1helpful
5answers
Does the Eclipse Fit Clip Plus have resume play functions?
I have just discovered that if you pause the player and then let it shut off on its own then press pause again later to wake up the unit and again it will pick up where you were. Now, I don't know if it uses any battery life when it's sleeping so will just have to experiment there. But the key here seems to be NOT actually turning it off. Turning it off will reset it to song #1 every single time. Which is really obnoxious.
1helpful
3answers
How to set up an eclipse fit clip plus mp3 8GB and how to download music without using iTunes?
To use it without iTunes, you can just go to any free music download site and download and save music. Then go to your files and drag all of the music you want on your player into teh player, adn into the MUSIC folder. Then eject the player. It should be able to play the mucic. For the free download site I reccomend www.mp3juices.com but that's just me. Hope this works for your music problem!
2helpful
How do you get your 6700 to play music etc on the headphones
Your phone includes a media player for listening to songs and viewing video clips. Music and video files stored in the music folder in the phone memory or on the memory card are automatically detected and added to the music library.
To open the media player, select Menu > Media > Media player.
Music menu Access your music and video files stored in the phone memory or on the memory card, download music or video clips from the web, or view compatible video streams from a network server (network service).To listen to music or play a video clip, select a file from the available folders and Play.
To download files from the web, select Options > Downloads and a download site.
To update the music library after you have added files, select Options > Update library.
Play songs
To adjust the volume level, press the volume keys.
Operate the player with the virtual keys on the display.
To skip to the beginning of the previous song, select icon_28.giftwice.
To rewind the current song, select and hold icon_28.gif. Release the key at the position you want to continue the music playback.
To close the media player menu, and to continue music playback in the background, press the end key.
To stop the media player, press and hold the end key.
Hope it helped.
39helpful
4answers
How do i download music onto my eclipse?
Hello.
Welcome To Fixya Community
There you go :
  1. Connect the MP3 player to a working USB port.
  2. When the unit is connected to your computer, it will create a gray and green icon in the system tray (lower right hand corner of your desktop). The icon will be called safely remove hardware.
  3. Go to the “My Computer” section of your computer. In there you will find a section called “devices
    with removable storage”
4. Locate the drive created by the unit, generally just called Removable Disk, with a letter in Parenthesis. Drive letters vary depending on your system configuration.
5. Open the drive by either double left clicking on the drive itself, or by right clicking to open the option menu then left click on the desired drive.
6. Locate the music stored on your computer. Generally this is stored in the “My Music” folder of your computer.
NOTE: if you are unable to locate the music on your computer, click on start,search, files and folders, then search for “*.MP3, *.WMA”.
7. Once you have located the song files, you can right click on the song itself, and select “copy”.Open the removable disk drive, right click on in the empty space, and select Paste. This will transfer the song on to your MP3 player.
8. Repeat step 7 for as many songs as you want to copy on to the unit.
Additional Help:
Eclipse TCH828 Manual Guide
Thank You
Let Me Know If You Need Any Further Info
Best Regards
My sansa 8gb clip shows 'empty' for all music when in fact there is 7gb of music on it.... and i cant sync on any more songs. What should i do?
have you synchronized the 7gb music that is placed on the clip
select all the music and go to the properties remove the hidden attributes and read only tick mark
apply settings restart your device it should work now and show all the music in all music and make sure the music files are in the root directory of the drive that is they are not stored inside any folder
Will turn on but message appears saying "Not enough space for music DB. Please free 30mb." then shuts down.
I had the same problem two days ago.
Working on the assumption that the problem was a corrupted file, here's how I fixed it. As you'll see, I connected my Clip an Macintosh computer to fix it, but there is probably an analogous procedure using a PC. But I'm not very PC savvy, so someone else will have to figure that out.
Also, I don't know that all the following steps are needed, for example, trashing the old content folders and creating new ones, but this is what I did, and success resulted:
Connect Clip to Mac
Click on Clip's icon to open it.
Open up all content folders and drag songs, audiobooks, podcasts, etc. to trash and empty trash. (The idea is to get rid of the corrupt file, wherever it is.)
Drag all Clip system files to a new folder on the Mac desktop to copy them. This will include DID.bin, RES_INFO.SYS, SYS_CONF.SYS, version.sdk and WMPInfo.xml (Basically, I copied everything that wasn't a content folder.)
Don't bother copying content folders AUDIBLE, AUDIOBOOKS, MUSIC, PODCASTS and RECORD. (Later, you'll create new folders to replace these, to ensure that no corrupted file is reloaded to the Clip.)
Go to the Mac's Utilities folder. Launch "Disk Utility." Select Disk Utility's "erase" function. On the left, where disks are listed, select the Clip. Click on the "Volume Format" dialog box and choose "MS-DOS filing system." (Don't bother with any of the erase options, such as replacing all data with zeroes. Just do the basic erase.) Erase the Clip.
When erase is completed, drag copies of Clip's system files from Mac desktop back onto Clip icon.
Use "new folder" function to create new AUDIBLE, AUDIOBOOKS, MUSIC, PODCASTS and RECORD folders on the Clip.
Eject Clip from Mac and note whether the screen shows the Clip "refreshing" normally. If it does, you're in business.
Top Eclipse Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
