Everest Refrigeration EMGR24 Commercial Refrigerator Logo
D
David Nix Posted on Dec 05, 2015
This cooler stops cooling. I can turn it off for a few minutes then turn it back on and it will cool again but stops cooling in a few hours again then stops
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
tip
My freezer compartment of my Daewoo fridge is cool (though not as cool as as it...
The fridge gets it cold air from the freezer. There is like an air tunnel that goes from the freezer (usually in the back) to your fridge to provide cold air.
What probably happened it the tunnel is blocked with ice or another liquid. The easiest thing to do is unplug the fridge for 24 hour so the ice can melt.
If that doesn't help, we will have to manually clear the debris in the tunnel.
on May 31, 2010 • Refrigerators
It just stopt cooling ([email protected])
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Wine cooler cools but it does not turn on again . need to unplug and plug again ,but in doing so I erase settings thank you
Possible that the error is in the main program controller unit of the coolerr. It might be hanging up due to some errors in the voltage or the sensors.
make sure the connections are tight , check the thermostat settings, reduce to lower level, allow the unit to cool off , unplug for few hours and check again. if not check your program controller unit.
5helpful
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Ps3 over heating
switch of the console, first by holdin the power button for two seconds then the main power switch at the back. then pull out the power cord. wait for it to cool. dust it gently put it in an open space standing(vertically). when it cools after a few hours, try to turn it on again.
2helpful
Top Everest Refrigeration Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
