Starts the grinder by itself, with no buttons pressed
SOURCE: coffee maker won't start and just beeps when plugged in
The door on the top is not closed properly. When you open the top door(cover),you will see a button that is located on the top of the grinder cover. that is a switch that tells the coffee maker that the door is closed and can safely make coffee..please check that all parts are in place and top door(cover) is closed comepletly. good luck.
SOURCE: cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
SOURCE: The grinder does not work
I just sent an email to the following address: [email protected]
explaining the problem. I'll repost here when I hear back.
SOURCE: cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
SOURCE: I Have a Cuisinart Automatic
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
