Dragon Touch Touch 7 Purple Dual Core Y88 Google Android 4.1 Tablet PC Dual Camera HDMI Logo
Mlchael Powell Posted on Dec 05, 2015
Keeps saying connect charger even wben charger connected.iam trying to charge tablet
abdul hadi
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Dec 07, 2015
abdul hadi
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
512
Points
12
Probably your charger is broken or your charging port is broken. either way, if the charger is broken, its cheap to replace. if the port is broken, its cost a bit more
Dragons touch tablet wont charge up even when charger connected
its either you need a new charger (assuming your charger is broken) or you need a replacement on your charging port (it can be costly, try replacing a new charger)
2answers
I need to charge my tablet to start but it will not charge
Some Tablet PCs ships only to their original chargers , some can also be charged through your computer 's USB connection . Are you using the original charger ?
MY i pad will not charge
As soon as you connect your iPad to a working charger, it will beep. If you plug in the cable and you don't hear the beep, assume something is wrong. Just find out what, the cable or the charger.
Don't try to charge the iPad with a computer, because the 500 mA a USB connector from a computer can give, is not enough even to start.
But you can use a computer to test the cable, because the iPad should beep and say on the screen not charging.
If there is no beep when connecting to a computer, you have to use another cable. If it beeps, buy a new charger. 5 Volt 2 A. The best an Apple charger.
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
How can I get my Maxwest Tab-9100 to charge?
This can happen when a faulty charger isn't providing enough voltage/current. Faulty chargers can provide enough power to trigger the 'Charging' indicator and maybe even to power the unit but not enough to energise the units charger circuit. Try another charger (same voltage) or charging it through the USB socket.
2answers
Battery not charging
Is it loose connection. or any problem with charger or tablet. give it to any service centres
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
2answers
MotorOLA XOOM battery won't charge
Keri
Maybe a bad charger.
Mark
Motorola Support
2answers
Iam unable to turn it on, any help would be great
does the light come on when you plug in a charger? if so try turn it on with the charger in and on. and hold the power button for at least 5 seconds, if theres a light to indicate charge then theres power to it but could be some other fault internally, you have to try the tablet with the charger in and hold the power button for 5 seconds and you can leave the charger plugged in for an hour to see if it says charging just incase its a bad battery.
Top Dragon Touch Tablets & eReaders Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you a Dragon Touch Tablet and eReader Expert? Answer questions, earn points and help others
