Cars & Trucks Logo
T
Tina Cotterill Posted on Dec 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio sometimes works
Radio face is showing but no sound through speakers then couple days later all is working for about a day then stop again. fuses are ok wiring to speakers seem fine. someone said it might be the control chip?? PLEASE HELP
Randy Ohler
Level 3:
  • Cars & Trucks Master 14,585 Answers
  • Posted on Dec 05, 2015
Randy Ohler
Level 3:
Answers
14585
Questions
8
Helped
3946953
Points
39683
Bad solder joint in the radio. Chips don't come back to life when they die. Something that has to be searched for after the radio is tore down.
1helpful
Radio speakers only give off very high frequency low vol. sound.
Keeping it as simple as possible, sounds to me like there is a fault in the wire itself, test the radio by using different speakers and wire.
There is also a fuse or 2 behind the radio (built in) and they sometimes blow, the sporadic working speaker can be a symptom of a slow-blow fuse going. Hope this helps..
1helpful
Have a 2008 Maxima SE-all interior lights and trunk lights stopped working over a year ago (dashboard lights work).Replaced fuses a couple of times, works for a day or so and the goes out. Mechanic do
You seem to have a short in that fused system. Think back to when this problem started, did you have some work done such as a new radio, or a power antenna, or maybe speakers. If this brings something to mind those items should be checked. GOOD LUCK FRIEND.
Car radio diagnostics
I think the Fuse melted away and is blown .
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
2helpful
1995 Pontiac Grand AM SE. Heater fan works for weeks then won't go, try a couple hours later then it goes.
It sounds like the brushes on armature for (blower motor ) are worn. Sometime a bad spot on the armature from not being used often and also by being in the engine compartment where it is exposed to condensation. When the brushes stop at that particular spot, the blower will not start spin process unless it draws alot of current that may be why the fuse blew. You can remove the blower and examine or just make the change.
2answers
2005 SC 430 Lexus--audio system goes off for no rhyme or reason.
somewhere you have a short in your wires that triggers the fuse in your radio
2answers
Fuel pump stops working,Then runs again later
You don't say how old the truck is - or how old the pump is - most likely it is the pump 'dying' as you try it -
I would look near the tank and find the ground wire -[ it may be on top of the tank] - the most common fix is the fuel pump and sadly it sounds like this is it --
Also - Take down the Vin # and call the local dealer - - ask about recalls and Service bulletins.
6helpful
3answers
03 chev silverado radio on but no sound
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
