My phone worked several days after I switched #'s. Then I could only text but not make/receive calls. I talked w/cs and they sent me a new Sim card. Now I can't even text on it. Phone Info says no service and it doesn't give MEID/IMEI. When you dial *#60# it says network unavailable.
SOURCE: How to install recovery on motorola droid razr XT912
We can't recommend installation of third party recoveries.
Mark
Motorola Support
Seems that you will have to take it to a proper phone shop. They can try to restore it there, but if not, they may have to send it away. There is nothing you personally can do without your code. Hope that this helps and good luck
SOURCE: I have a motorola Droid Razr XT912 verizon and I would like to unlock from the network
Daniel-
For use with who? What happens when you put your SIM in?
Mark
Motorola Support
Sarah
The Motorola Droid is a a Verizon phone, not straightalk.. If the Original then it is long out of warranty. We have had multiple Droids so I'd like to confirm which one. It could be the battery. If the original droid, then it has a depleted battery. In some cases charging it overnight might recalibrate the battery. If it has been used past its charge cycle times then it will need to be replaced.
You may also consider going to Motorola Owners Forum
Mark
Motorola Support
SOURCE: howto unlock verizon network locked motorola droid razr m xt907?
Hi Olga,
In that case you will need to contact your carrier, so they can help you with that.
Reagards,
Maya
Motorola Support
