Question about Samsung Washing Machines
How do u fix the burning on my Samsung washer, I heard something pop or break on it then the burning smell
    Habit-Forming:
    New Friend:
  • 7 Answers
Doesn't sound good, is this an electric washer? if so run to the breaker and turn it off if it isn't tripped already!
if it is a gas dryer, run faster!!
once you have removed all the power from the source at the receptacle it will be safe to begin looking for what caused the initial action you referenced.
Posted on Dec 04, 2015
SOURCE:
duby1990
  • 370 Answers
SOURCE: Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Posted on Nov 17, 2008
  • 163 Answers
SOURCE: washer wont spin
check belt under the machine.maybe the pump or another pulley is locking up.turn your pulleys by hand to see how much tension is their.you may just need a belt
Posted on Mar 06, 2009
  • 130 Answers
SOURCE: crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 07, 2009
ned_san_jose
  • 234 Answers
SOURCE: GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Posted on Jul 07, 2009
SOURCE: GE washer stopped spinning and smell of burning out lingered
I am going through this right now and best I can tell..needs a new belt. Pop the front off of your washer (UNPLUG IT FIRST:)) and see if there are black shavings on the bottom. The appliance place where we usaully order our parts from do not carry this belt in stock so it will have to be ordered. Price from them was $19.00+ tax
Posted on Aug 13, 2009
Run microwave empty
I would never recommend using a microwave that emits a burning smell.
Mar 27, 2014 | Samsung Microwave Ovens
Tv picture went out
Sorry bad news these TV's work off of lights that shine thru the back of the screen if you heard a pop it was the power board that turns on those lights not an easy fix sorry.
Jan 28, 2013 | Samsung LN40D550K1FXZA - LN40D550 40 1080p...
I heard a pop and smelled something that smelled like it was burning then the protect light came on then it shut off
Where there is a smell something burned---my suggestion is have a shop look at the unit and get a repair estimate---you can try that yourself but taking apart correctly is not always easy and there is a chance you might cause more problems---even if you find burnt part/s you will not likely know what got them.
Nov 08, 2012 | Mitsubishi M-VR1000 Receiver
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Nov 17, 2008 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
