Irons Logo
A
Anonymous Posted on Dec 04, 2015
Sisan French Steam Iron. Lost the power cord. Where can I purchase another?
Layla Daniels
Level 2:
Scholar:
  • Expert 76 Answers
  • Posted on Dec 04, 2015
Layla Daniels
Expert
Level 2:
Scholar:
Answers
76
Questions
0
Helped
68042
Points
207
Sisan French Steam Iron Replacement 2 Prong Power Cord ...
www.ebay.com > itm > Sisan-French-Ste...
Sisan French Steam Iron Replacement 2-PRONG POWER CORD Garment Steamer in Home & Garden, Household
lizard00420
Level 2:
  • Expert 37 Answers
lizard00420
Expert
Level 2:
Answers
37
Questions
0
Helped
11926
Points
104
EBay or alibaba.com
Where will i download instructions for sisan steam iron
http://www.ehow.com/how_4745214_use-steam-iron.html
Oct 18, 2014 • Irons
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Straightener nano silver
please make this revision and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the power cord , and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the power cord. Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
Nov 29, 2013 • Irons
Water distiller keeps shutting off
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat.and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle .
Test the heating elements and power for blowing fuse.use the DVOM
God bless you. see the diagram 2_6_2013_8_23_01_pm.jpg2_6_2013_8_23_30_pm.jpg
Feb 06, 2013 • Irons
I have a Tefal Pro Express Turbo iron (purchased in 2005). In the past 2 days the steam is constantly on - the button does not appear to be stuck. I can't get the steam to stop... unless I take out...
Yes, if your electric cord was extremely hot to touch is not common. It's posing danger to your unit and to your entire electrical system that may cause fire. Please let a qualified electrician inspect and repair your unit. The unit thermal fuse may not functioning that automatically switch off or cut the electric power of your unit when it gets too hot. Thank you for asking.
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
1helpful
3answers
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Top Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Iron Expert? Answer questions, earn points and help others
